R56 Washing the key fob
Washing the key fob
Shhhh...don't tell anyone, but I inadvertently let my key fob in my pocket and it went through a one hour wash cycle and 45 minutes in the dryer.
When I found it taking the clothes out of the dryer I thought, Oh great, now I am out $85 for a new one. At least that's what I have heard they cost.
It was very hot to the touch, so I let it cool down before trying it, but all is well and it seems to work fine. I can hardly believe I was so lucky I didn't ruin it but I am sure happy. I wonder if anyone else has done this.
If you accidently wash one of these, most of the time as long as you give it a chance to dry out before attemping to use it, you're fine. My wife's Mazda 6 key got washed a week ago. I just let it air dry and it was fine. On the other hand, I've never experienced having one go through a dryer cycle. That could possibly ruin one more so than the water. I'm glad you didn't have to spend that amount of money.
Don't ask how I know I will not tell.
$285 + tax is what my dealer charged me a year ago any way.
Yep! I've run mine through the wash/dry as well.
Still works fine and smells Rain Forest Fresh!
Jim
Jim
Next time, swish it around in some deionized (or distilled) water when it comes out of the pocket after washing/drying and then let it dry completely before using it. The objective is to rinse out residues from ordinary tap water which can interfere with the electronics.
BTW, electronic boards are routinely washed after manufacturing.
But not with batteries in place.
I suspect the fob is designed to survive being washed. It is obviously a common occurrence.
You can also use a zip lock bag or tuperware w/ rice. Does a very good job.
It's use in the salt shaker is more about keeping the salt free flowing than absorbing moisture.
Before ordering from ebay better ask your dealer if they can/will reprogram it for your car, and what they will charge.
Actually this is an old wives tell and isn't correct. Cold dry rice does a poor job of absorbing water. It must be heated to a high temperature in order to break down the starches before it starts absorbing any significant amount of moisture (water).
http://lifehacker.com/269427/dry-out...adgets-in-rice
http://www.audioholics.com/reviews/p...and-conclusion
More info is required to assist with your situation:
Did you use the delicate or heavy duty wash cycles? What were the wash and rinse cycle temperatures? Front load or top load?
Did you wash with just whites or a mixed load?
Chlorine bleach or all fabric detergent?
Did you dry it on permanent press setting? Timed or automatic?
Did you use fabric softener in the wash or those sheets in the dryer?
(...and my wife thinks that I don't know how to do laundry. I just don't let on that I do. Besides, I never ask her to wash the cars. Why should I do the clothes?)
