Cooper (non S) Modifications specific to the MINI Cooper (R50).
Engine gone :(
Old Jan 9, 2010 | 06:32 PM
nickbmw's Avatar
nickbmw
Engine gone :(
Was out tonight, typical Saturday night, on the way out, i was playing with an RX8, i was in fourth gear about 5000rpm, i heard a strange noise for a very short time, 1-2 secs, then the engine died. I pulled off, opened the hood, checked as many things as i could, there is no oil anywhere or under the car, the oil in the dipstick is clean and the level is ok, the antifreeze tank is clean and the level is ok, also no spark plugs stripped, i had no error codes, and i had absolutely no signs that sth could go bad, the car felt very good and strong. The belt is fine. A few minutes later, i tried to start it, the starter motor works ok, but the engine won't start. The only thing i didn't like was that there was evaporated oil coming off the intake, like white smoke, also from the dipstick and from the oil cap. Tomorrow morning i'll take off the spark plugs. Any ideas what has possibly gone wrong?
A few details. The engine is not stock, oil used Castrol Edge Sport 0W-40, oil changes every 10.000km (about 7k miles), rev limiter 7350! I didn't ever had any problems with the engine.
Old Jan 9, 2010 | 06:58 PM
ZippyNH's Avatar
ZippyNH
White smoke....might be coolant, but it sounds like you are experienced enough to know the difference!! The worrisome part the "strange noise", followed by engine stoppage...(was it metallic screech, or just a whirr or buzz??)...and the fact you have a 7350 red line.....hope you didn't spin a bearing previously...and just now broke something internally....from oils starvation/stress/wear. Maybe you will get lucky and find out it is an ignition problem, maybe a timing chain....or something...Over my head I'll admit.....But I remember seeing your posts and I feel for ya....sounds like a good car. Good Luck!!
Old Jan 10, 2010 | 05:35 AM
denny_CMI's Avatar
denny_CMI
good luck nick! Let us know what's the problem
Old Jan 10, 2010 | 05:49 AM
NightFlyR's Avatar
NightFlyR
White Smoke normally means a head gasket, but that would not normally make the engine stop, odd that no codes were thrown
Old Jan 10, 2010 | 05:54 AM
nickbmw's Avatar
nickbmw
I will upload photos of the spark plugs in a few minutes... they are pretty dissapointing...
Old Jan 10, 2010 | 06:08 AM
nickbmw's Avatar
nickbmw
Any feedback welcome...
Attached Thumbnails Engine gone :(-p1000792_1.jpg   Engine gone :(-p1000796_1.jpg   Engine gone :(-p1000794_1.jpg
Old Jan 10, 2010 | 06:13 AM
NightFlyR's Avatar
NightFlyR
Looks like a broken valve or a ring broke off in that cylinder :(
Old Jan 10, 2010 | 06:17 AM
nickbmw's Avatar
nickbmw
We'll see when the mechanic will open the engine in the workshop, i really don't know
Old Jan 10, 2010 | 06:30 AM
NightFlyR's Avatar
NightFlyR
Sorry , wish you were closer I would help you tear it down, good luck keep us informed
Old Jan 10, 2010 | 06:32 AM
nickbmw's Avatar
nickbmw
Really thanks mate, i'll keep you informed with as many pics as i can
Old Jan 10, 2010 | 07:30 AM
ZippyNH's Avatar
ZippyNH
OUCH....then again....it is an excuse to do more mods to the engine! Mixed blessing if you have the Money I guess. There is a silver lining to everything if you have the right attitude!
Hopefully most of the internals are OK....I'll be watching. Keep smiling, and know it will bet better than ever when fixed!!
Old Jan 10, 2010 | 07:36 AM
nickbmw's Avatar
nickbmw
I wouldn't be very sad if i had a second car to do my everyday jobs, this is my main problem.
I already have a Cooper S engine block, crank and rods, i am just waiting to open the engine and see, then i'll order a set of high compression pistons and build a stronger engine, in theory...
Old Jan 10, 2010 | 09:22 AM
nickbmw's Avatar
nickbmw
The spark plug in cylinder 1 severely damaged :
Attached Thumbnails Engine gone :(-p1000797_1.jpg   Engine gone :(-p1000798_1.jpg
Old Jan 10, 2010 | 09:46 AM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
That's not going to be a cheap fix. We just put a motor in a car that had a broken piston.
Old Jan 10, 2010 | 09:50 AM
nickbmw's Avatar
nickbmw
This is also a very good option, and maybe the cheaper. I haven't decided yet what i'll do, really. On one hand i want to build an engine with the R53 block (for the oil squirters), and the stronger rods the R53 has, on the other hand, i am taking a risk again.
Old Jan 12, 2010 | 11:35 AM
nickbmw's Avatar
nickbmw
We couldn't believe in our eyes when we removed the cylinder head with my mechanic...
Attached Thumbnails Engine gone :(-dsc00351_1.jpg   Engine gone :(-dsc00352_1.jpg   Engine gone :(-dsc00355_1.jpg
Old Jan 12, 2010 | 11:39 AM
NightFlyR's Avatar
NightFlyR
Originally Posted by nickbmw
I couldn't believe our eyes when we removed the cylinder head with my mechanic...
O U C H !!!!!
Old Jan 12, 2010 | 11:40 AM
nickbmw's Avatar
nickbmw
And a few more..
Attached Thumbnails Engine gone :(-dsc00356_1.jpg   Engine gone :(-dsc00357_1.jpg
Old Jan 13, 2010 | 01:48 AM
FlyinScotsman's Avatar
FlyinScotsman
Sorry to see this... I had a similar catastrophic failure in a built motor (Non-MINI) many years ago due to an oil pump issue.
From your pic of the #1 combustion chamber it looks like both the exhaust valves broke in different places & the stems are still in stuck in the guides. Check the entire valve train, especially the cam caps & journals for galling/overheating & make sure the cam still turns freely in the head. Your mechanic can also put the cam in a lathe or some V-blocks & check the run-out to make sure it's OK.
Once he gets the bottom end torn down he can check the rod & main bearings etc for signs of lubrication and/or overheating issues.
To get back on the road quickly, can you use Cooper pistons/rods with the S block & crank? Sourcing one OEM piston & rod might be quicker than waiting for a custom piston set. If the S rods can't be used, Cooper rods can always be cracked tested & stress relieved to improve them for not much money. A good machine shop can do this & balance the whole bottom end as an assembly.
You might be able to get additional feedback posting on Motoring Alliance & Mini-Torque. Good luck, let us know how it goes & get the A/F ratio checked after the rebuild!
Old Jan 13, 2010 | 02:33 AM
denny_CMI's Avatar
denny_CMI
OMG!
Did You have a wideaband lambda ora an EGT???
Does your mechanic think it was due to a lean a/f or it was just something that broke down?
Old Jan 13, 2010 | 03:14 AM
nickbmw's Avatar
nickbmw
Thanks for your help guys, the photos are taken from my mobile phone and are not very clear, i'll take better shots soon with my camera. I don't have egt or a widebang sensor, by the look it seems that the combustion is ok, there are no signs of detonation on the pistons or the head, or on the spark plugs, on the rest of the cylinders, but you never know. My mechanic thinks sth broke down and caused the damage, possibly because of the rev limiter. (7300)
FlyinScotchman, i will check everything you said, to see if it had proper lubrication. The stems are trully still in the valve guides, and they broke in different points. I don't have a clue yet about the block, because it is still on the car and assembled.
Someone mentioned in another thread, that the Cooper S rods are shorter, i will check that. About the Cooper pistons and rod, i don't know how safe it is to use them again and rev high.
Old Jan 13, 2010 | 07:00 AM
Revolution Mini Works's Avatar
life is a risk that you won't wake up the next day
Old Jan 13, 2010 | 12:53 PM
denny_CMI's Avatar
denny_CMI
yes, it may have been a too high rev limiter:here in italy tuners use different valve spings and valves to go over 7000 rpm...
Good luck nick!
David.R53
Sep 1, 2015 06:49 PM
Aug 21, 2015 10:07 AM
finn
Aug 21, 2015 07:59 AM
truedrew
R60/R61 Stock Problems/Issues
Aug 10, 2015 10:39 AM
