R55 turbo heat shield
Old Jan 7, 2010 | 03:34 AM
doug daniele's Avatar
doug daniele
turbo heat shield
Need to locate a more efficent turbo heat shield for my mini clubman s 2009 doug daniele E Mail dougbiking@hotmail.com
Old Jan 7, 2010 | 07:06 AM
Helix13mini's Avatar
Helix13mini
Call Way Motorworks, he sell 'em.
Old Jan 7, 2010 | 07:42 AM
lotsie's Avatar
lotsie
Here is a link to Way's heat shield;
http://www.waymotorworks.com/product...1&cat=0&page=1
Mark
Old Jan 7, 2010 | 09:37 AM
joshK's Avatar
joshK
I have Way's heat shield on my car and have been very satisfied with it. If you do a search, I did a DIY with pics back when I put it on. Everything fits under the stock heat shield.
Old Jan 7, 2010 | 10:55 AM
NJclubman's Avatar
NJclubman
Heat shield
FYI - I went with M7:
http://www.m7tuning.com/parts/produc...roducts_id=137
Old Jan 7, 2010 | 01:34 PM
ART ED's Avatar
ART ED
I watched the video on M7 and found it very helpful. He made an interesting point about wrapping the turbo so much, that eventually you could fry the bearings. May have to go that route now that my scoop has been replaced. Thank you for the link. BTW...the original bolts that were on the OEM heat shield, did you discard those and go with the two bolts that came with the new heat shield?
Thanks, Ed
Old Jan 7, 2010 | 04:49 PM
Headlands's Avatar
Headlands
Forgive my ignorance on this subject, but what advantage do these other heat shields give to the engine?
Old Jan 7, 2010 | 04:59 PM
onefish2's Avatar
onefish2
I have the NM Engineering turbo heat shield installed.
Old Jan 8, 2010 | 04:54 AM
doug daniele
Heat shield
Where do I get one Doug Daniele dougbiking@hotmail.com
Old Jan 8, 2010 | 08:32 AM
lotsie's Avatar
lotsie
Do a search from the 2nd gen coupe talk forum page, type in heat shield, there is lots of discussion on the different kinds, and reasons for installing them.
mark
Old Jan 8, 2010 | 10:05 AM
miniemee's Avatar
miniemee
+1 for the M7 heat shield. The problem with the stock shield is that the heat is being vented right under the hood scoop causing it to warp. The M7 shield is simple to install and vents the heat towards the sides of the car and away from the hood scoop.
Old Jan 8, 2010 | 11:37 AM
slinger688's Avatar
slinger688
I also have a M7 and can say I like it. More for my hands not getting burned from a hot turbo when I am in the engine bay.
I have read a lot about the turbo wrap and how it can fry the turbo but so far, there has been no reported incidents of that on NAM that I know of. If you want to buy a less expensive turbo wrap, look at this:
http://www.summitracing.com/parts/DEI-010113/
Old Jan 8, 2010 | 12:14 PM
lotsie's Avatar
lotsie
I would like to read about how a wrap can fry a turbo, could you provide some links. I do know our dealer thinks MINI should have thought of it being OEM.
Mark
Old Jan 8, 2010 | 12:41 PM
inimini2007's Avatar
inimini2007
Think of steam pipes...you put a wrap and lagging...to keep the heat in...stays cool outside.
Old Jan 8, 2010 | 04:32 PM
NJclubman's Avatar
NJclubman
In NJ they haven't seen many problems with the warping of the hood scoop but I would assume it would be worse in a hotter climate and very hard driving. Dealer indicated that Mini is replacing warped ones under warranty so no worry - service rep thinks it might just be a run a inferior plastic compared to others.
Replacement fiber scoops are better.
Old Jan 8, 2010 | 04:35 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
Check out our website, We sell our WMW turbo wrap, M7 and NM heatsheilds.
Old Jan 12, 2010 | 07:38 AM
accordselux's Avatar
accordselux
I'm planning on getting the NM engineering.
I've heard about the fitment issues on the M7 version (which apparently have been fixed, but still), plus the price point is too much for me.
The turbo wrap is something i'm on the fence about as well, because i've heard all sorts of things about oil temp and bearings, etc. Better safe than sorry.
Old Jan 12, 2010 | 11:07 AM
doug daniele
I'm going to do my nm shield installation probably this weekend. Will post results. Doug Daniele e mail address dougbiking@hotmail.com
Old Jan 15, 2010 | 04:50 AM
doug daniele
Installed my nm shield . It took all of 15 minutes. Clear is good . Noww to see heat reduction at hood scoop!!!!???
rtk90
Aug 29, 2019 09:08 AM
M7Speed
Sep 4, 2015 10:47 AM
Sep 3, 2015 01:45 PM
M7Speed
R58 :: Coupé Talk (2012+)
Sep 3, 2015 07:29 AM
M7Speed
Sep 3, 2015 07:27 AM
