Navigation & Audio HALP!!!
Old Dec 26, 2009 | 06:13 PM
skakid812's Avatar
skakid812
HALP!!!
I had a 12' audo pipe sub put in with a picasso 170watt amp today at a audio shop, it runs fine and I turned my car off to go into work and came back out and my trunk is shaking and the bass is going NUTS! and as soon as I pop my trunk it stopped, close the trunk it starts. any idea on what is wrong? I know its just wired from the trunk to the battery for the most part.
Old Dec 26, 2009 | 06:39 PM
skakid812's Avatar
skakid812
and it was installed by a shop by the way, I warned them and said they might have problems because the mini's wiring is weird and they shrugged it off/facepalm
Old Dec 26, 2009 | 06:53 PM
Robin Casady's Avatar
Robin Casady
Teka et buck ta tha audo shop. Not sure what they did wrong, but it could have to do with the what they tapped for amp on power signal. I had strange results when I tapped into a climate control fuse.
Old Dec 26, 2009 | 07:04 PM
skakid812's Avatar
skakid812
what should I tap into then? idk if its relevent im sure it is but since the audio was installed the passenger window toggle works to autodown, but not autoup, driver side works fine. its a 2010 mini S
Old Dec 26, 2009 | 10:19 PM
Robin Casady
It might not be irrelevant.
I believe the safest thing is get the auto-on signal from the cig lighter circuit. The front and back sockets are on the same circuit, so either one would do. Don't use an Add-A-Circuit tap in the fuse box because the circuit is 20 amps and there is no tap available that can handle that much current.
Your amp's power cable should go directly to the battery.
hellothom
Mar 11, 2017 01:43 PM
hellothom
Tires, Wheels, & Brakes
Dec 1, 2014 08:46 PM
avenger
Apr 1, 2014 05:49 PM
MrNintend0
22
May 10, 2011 05:13 AM
JohnnyVillan
Oct 15, 2009 08:58 AM
