Interior/Exterior How to remove these silver tubes next to radio
I was wonder if anyone knows how i can take those silver tubes next to the radio out. I want to attach some foam tapes to it because its rattling so loudly.
Remove the under dash panel on the driver side.
Then I usually take the center dash trim piece below the speedo off or at least loose
Then pull the screws out the downtubes and remve.
Now since you have an 05 you may have to pull the center console because sometime in 05 they changed the tubes so they flared at the bottom so they won't come out unless the console is out.
If your unsure get a Bently repair manual, it's the best for repair instructions.
ltjpunk7
Sep 6, 2015 07:32 AM
