Interior/Exterior How to remove these silver tubes next to radio
Old Dec 16, 2009 | 07:01 PM
lx.josh's Avatar
lx.josh
I was wonder if anyone knows how i can take those silver tubes next to the radio out. I want to attach some foam tapes to it because its rattling so loudly.
Old Dec 16, 2009 | 09:08 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
Remove the under dash panel on the driver side.
Then I usually take the center dash trim piece below the speedo off or at least loose
Then pull the screws out the downtubes and remve.
Now since you have an 05 you may have to pull the center console because sometime in 05 they changed the tubes so they flared at the bottom so they won't come out unless the console is out.
If your unsure get a Bently repair manual, it's the best for repair instructions.
Old Dec 16, 2009 | 10:50 PM
PBlack's Avatar
PBlack
http://documents.victorytechnologies...roduct/950.pdf
hopefully this link works for u......
Old Dec 16, 2009 | 10:53 PM
lx.josh's Avatar
lx.josh
GREAT! Thank you very much. I will try it in the morning :D
Old Dec 17, 2009 | 12:40 PM
Act_04's Avatar
Act_04
These silver tubes are called "downtubes" (at least on this forum). Do a search on NAM for 'how to remove downtubes' and you should get plenty of info.
ltjpunk7
Sep 6, 2015 07:32 AM
Zettinger
Aug 25, 2015 04:04 PM
minicoclub
Aug 25, 2015 09:07 AM
veevsato
Aug 5, 2015 04:42 AM
