R56 Only 410 miles and exceed 4500rpm
I thought it should be covered here but I could not find it. Sorry if this is already covered.
Ouch... it was close to 4500rpm
when I drove wife's 2010 Mini cooper S yesterday. While I driving I just wanted to try to use the paddle shifter (since I drove only 6 spd manual Mini cooper S), so I push the paddle shift and more gas.... wow suddenly rpm went to close 4500rpm, so I off gas quickly... probably be rpm was 4200 or 4300 or 4400... but this is first time to get over 4000rpm.
The manual said that "... but do not exceed the following ... 4500rpm or 100mph ..." I hope it won't hurt the new engine
I just want to hear the engine will be fine, but what do you guys think? is she going to be okay?
when I drove wife's 2010 Mini cooper S yesterday. While I driving I just wanted to try to use the paddle shifter (since I drove only 6 spd manual Mini cooper S), so I push the paddle shift and more gas.... wow suddenly rpm went to close 4500rpm, so I off gas quickly... probably be rpm was 4200 or 4300 or 4400... but this is first time to get over 4000rpm.The manual said that "... but do not exceed the following ... 4500rpm or 100mph ..." I hope it won't hurt the new engine
I'd hit 6k rpm two weeks into the purchase, trying to race by boss's S2K on the ramp to the highway..
I lost tho...
I lost tho...
There are a lot of folks that swear your engine will perform better and last longer if you ignore the factory recommended break in.
I chose to go with the recommendation, but I certainly wouldn't worry about a quick excursion above 4K! I am absolutely sure that you will never see that one event cause a problem for you!
Enjoy your new car! They are awesome, aren't they?!?!?
You didn't even hit 4500, so why worry. Its only guidelines, so why worry. I hit the redline in Quentin exiting the dealer, it didn't seem to do him any harm. (Then I reread the manual and thought I'd better be a bit more gentle.) I slipped up plenty of times during break in on al the MINIs.
I've heard that bogging the motor is worse during break in than high revs (not applicable with the auto). I also think you're already well broken in at 400 miles anyways.
Don't give it a second thought - no damage of any kind could have occurred. Modern engines are very well machined and a break in period is far less important than in years past. You will find posts here in NAM from engine mechanics that go so far as to say that being too easy on the engine those first few thousand miles is actually not good for seating the rings in the engine.
I made several trips into the forbidden zone during breakin. None were intentional but after all the cars I've owned I didn't lose any sleep over it. I am one of those who feel a spirited breakin is good in the long run.
+1
Don't give it a second thought - no damage of any kind could have occurred. Modern engines are very well machined and a break in period is far less important than in years past. You will find posts here in NAM from engine mechanics that go so far as to say that being too easy on the engine thoses first ffew thousand miles is actually not good for seating the rings in the engine.
The break in period is BMW covering its own ***.
I try to vary engine RPM a lot and not rev the engine to high RPMs under load during the break in period. I will allow high RPM engine braking, however. I have read that it helps the rings seat. I will get back to you in 100,000 miles to let you know if it's working!
At least I will once my car comes in!
Thanks much
