R56 MCS BRG/Blk w/o bonnet stripes
Old Nov 28, 2009 | 06:27 AM
billc's Avatar
billc
I would like to buy a 2010 MCS, BRG/Blk, sport package, without bonnet stripes. When I use the configurator, it will not let me select that color without the stripes. I could get everything I want without the sport package, but that would cost me more. I asked the dealer about it and he said I could get the car without stripes at no extra charge, but don't believe him. Has anyone had this problem?
Old Nov 28, 2009 | 07:47 AM
Eds not-so-red MINI's Avatar
Eds not-so-red MINI
I've seen that on the configurator, too ... I had to do a big of mucking with it to get the sport stripes on BRG instead of the bonnet stripes. I believe that the stripes are installed by the dealer, so I think your dealer is right. My dealer never batted an eye when I told them I wanted the sport stripes instead of bonnet stripes. Plus, they'll install either one on a car that came without them after delivery if you want, which further suggests to me that they come out of the factory without them.
Seems to me they should be able to deduct the cost of the stripes if you really don't want 'em...it's not like they're doing anything extra to not put them on, other than remembering not to put them on!
Old Nov 28, 2009 | 09:08 AM
Robin Casady's Avatar
Robin Casady
In 2007, I got the Sport Package without the stripes. I believe the dealer is correct.
Old Nov 28, 2009 | 12:05 PM
Eds not-so-red MINI
The confusion is with the Mini configurator. For some reason doesn't allow you to delete the bonnet stripe in the Sport Package if your color is BRG. If you start with BRG, add the Sport Package, then select No Bonnet Stripe in the package options, it changes the color to Laser Blue. Then if you go back to step 1 to select the color again, rolling over BRG says 'THIS ITEM IS NOT AVAILABLE UNTIL YOU REMOVE NO BONNET STRIPES.' BRG is the only color it does that for. Crazy. I wonder how much extra Flash coding it took to do that ... and why.
Old Nov 28, 2009 | 12:36 PM
Robin Casady
That may be a side-effect of some other code in the Configurator.
Dealers have more flexibility than the Configurator. They can often order combinations not allowed to us online.
Old Nov 28, 2009 | 01:32 PM
billc's Avatar
billc
Yes, I think it's a software problem. Anyway I ordered the car, hopefully I'll get what I want. I was told I check the order and make changes, if needed, after I get the VIN number. Thanks for your comments,
Old Nov 28, 2009 | 02:34 PM
Robin Casady
As soon as the car is scheduled (at the factory) for production it is too late to make changes. You may only have a day or two before the order is frozen and cannot be altered. The exception is for items installed by the dealer.
Old Nov 28, 2009 | 04:32 PM
John Felix's Avatar
John Felix
Bonnet stripes are easily removed, and your dealer can do it for you should the car arrive with them in place.
caiken
Aug 27, 2015 06:55 AM
Drumsound
Aug 25, 2015 02:25 PM
minicoclub
Aug 25, 2015 09:07 AM
bctf1
Aug 6, 2015 12:55 PM
