R57 Help - top won't open past the sunroof position
Old Nov 20, 2009 | 10:12 AM
at7815's Avatar
at7815
I dropped off my R56 for service and got an R57 convertible as a loaner - the problem is, I can't open the top. I hit the toggle switch and it just opened the sunroof. I get some signal on the dashboard that looks like the car and then a piece of luggage on top. I thought it meant there was something in the trunk, but I checked and the trunk is empty.
Could some R57 owners help me with this? Am I doing something wrong?
TIA!
Old Nov 20, 2009 | 10:29 AM
Jeremy1026's Avatar
Jeremy1026
Moderator
Check the parcel shelf in the boot, make sure it is in the lower position, then make sure that the two locks on either side of the boot are down. (They are long black pieces of plastic.)
Old Nov 20, 2009 | 02:50 PM
at7815's Avatar
at7815
That worked!!! Thank you so much!!!
The parcel shelf was not in the lower position.
Old Dec 9, 2009 | 08:01 AM
Third Wave's Avatar
Third Wave
It's very particular about the shelf and those locks being in the proper place. The top will not work if everythings not right.
Freaked me out the first time too.
Old Dec 10, 2009 | 05:17 PM
Derepente's Avatar
Derepente
Ditto, i was pretty shockedwhen this happened To me.
Glad this got sorted out.
Old Dec 10, 2009 | 07:10 PM
gawannamini's Avatar
gawannamini
I have an R57 and does anyone out there actually use the shelf in the upper position to gain that tiny bit of space??
Old Dec 10, 2009 | 07:21 PM
Jeremy1026's Avatar
Jeremy1026
Moderator
I did once...then decided it was retarded...thus returned it to its original position to never move it again.
Old Dec 11, 2009 | 06:22 AM
Not4no1's Avatar
Not4no1
I do...only for the trip...
If I have to pick up both diapers & wipes from Sam's Club + the other misc things I can't leave there without.
But if I don't have any passengers, I put the diapers down on the passenger's floor & drop the top! ...So I usually go to Sam's by my self now
Old Dec 11, 2009 | 08:35 AM
sailordive's Avatar
sailordive
I move it to get an over stuffed roll aboard suitcase in the trunk.
rikaro
Aug 7, 2021 02:33 PM
Aug 21, 2015 12:58 PM
Aug 19, 2015 12:51 PM
dchang0
Aug 10, 2015 03:37 PM
