R55 Coolant Level-Cold Engine
Old Nov 15, 2009 | 01:52 PM
Kimbo80's Avatar
Kimbo80
I just went and checked the coolant level on my Clubman. The car has been sitting for 4 hours, and the reading is about a 1/2 inch below the minimum level. There are no leaks under the car or in the engine bay noticeable to the naked eye. Is this something I should be worried about?
Update: I ordered a gallon of BMW antifreeze from Bavarian Motorsport and will do a 50/50 mix with distilled water. I did a search and this there are some owners that have noticed the levels go down due to evaporation, but I'm surprised the dealer did not top it off the last time I visited them, when I had some warranty work done last month.
Old Nov 16, 2009 | 07:53 PM
b13mini's Avatar
b13mini
See if this post helps...
https://www.northamericanmotoring.co...rent-leak.html
Old Nov 17, 2009 | 07:28 PM
Kimbo80's Avatar
Kimbo80
Thanks for the link. My coolant level is no where close to emply like the poster's in the link you provided, but I will definitely keep an eye on it.
Old Feb 20, 2010 | 08:09 AM
Kimbo80's Avatar
Kimbo80
I have a slow leaking thermostat. They are fixing it right now.
Update: The dealer did a compression test and found out the thermostat was leaking. They replaced the thermostat and bled the cooling system.
Old Feb 25, 2010 | 05:51 PM
Kimbo80's Avatar
Kimbo80
Ugh......... I am going back to the dealer tomorrow. I checked the coolant, and the level has dipped about 1 cm below the minimum line after sitting overnight. I even placed a poster board underneath the engine bay, and there wasn't a single drop on it. I am wondering if it's the thermostat housing, which the 1st gen's are notorious for leaking or even worse the water pump or head gasket. I will keep everyone updated.
'09 Clubman, 4100 miles
Old Feb 25, 2010 | 06:03 PM
911Fan's Avatar
911Fan
If you're only replenishing a 1/2 inch loss, you can simply add distilled water without having to worry about mixing it with antifreeze.
BTW, it's a sealed system so coolant doesn't "evaporate". Assuming it was full to start with, there's a leak somewhere...
Old Feb 25, 2010 | 06:11 PM
Kimbo80's Avatar
Kimbo80
I have been topping it off with a 50/50 mixture of BMW OEM coolant and distilled water using a plastic jug w/ side markings. I have topped it off about 4 times since September between max and min. levels, and since they replaced the thermostat last Saturday, the level has actually been decreasing at a faster pace. I will keep everyone posted, once I return tomorrow.
Old Feb 26, 2010 | 12:26 PM
Kimbo80's Avatar
Kimbo80
I went to the dealer this morning, and they did a pressure test. The end result: no leaking according to the pressure test and visual inspection. The SA said the drop I am seeing (1 cm on the plastic tank) is do to being sucked backed into the radiator, when the coolant is cooling down.
Ugh......I will just have to keep an eye on the level and see if it drastically goes lower, then I will try a different dealer.
Kimolaoha
Jul 5, 2023 01:04 PM
W0TM8
Dec 19, 2019 07:50 AM
danielbrookes_9
Oct 3, 2015 12:51 PM
David.R53
Sep 1, 2015 06:49 PM
tylewis
Aug 18, 2015 06:53 AM
