Hard / Cold start issue RESOLVED!! *Vids*
Old Nov 13, 2009 | 07:50 AM
Case1220's Avatar
Case1220
ignore this...the problem continues
Last edited by Case1220; Nov 24, 2009 at 12:53 PM. Reason: This was false....the problem continues
Old Nov 15, 2009 | 07:41 AM
-=gRaY rAvEn=-'s Avatar
-=gRaY rAvEn=-
Moderator
The second video you recorded, was that the next day and a true cold start up or all videos done in same day ?
Old Nov 15, 2009 | 08:30 AM
thecigarman's Avatar
thecigarman
I reset mine at least 4 or 5 times during my attempts to correct the problem and it was not a solution. Right now I thinks it was due to bad gas...
Old Nov 15, 2009 | 02:03 PM
bratling's Avatar
bratling
Super Moderator
Originally Posted by Case1220
Hey everyone, I finally tracked down the problem behind the hesitation on start up. All it needed was a quick ECU reset using these steps: ... [/URL]
Thanks! Have bookmarked this for future "just in case" reference!
Old Nov 15, 2009 | 05:02 PM
-=gRaY rAvEn=-
Moderator
The wide spread issue of cold staring problems is where it doesn't start at all the first time you try to crank it over in the morning.
What you had in the first video is not the typical "cold start" problem.....
I fixed mine by changing the fuel pressure regulator attched to the fuel rail inside an aluminum housing, and replacing my injectors. Both of these parts have small rubber O rings. This area is subjected to huge amounts of trapped heat from the bottom of the intercooler and the engine manifold. My O-rings for all parts were brittle, and thus not keeping the proper amount of pressure in the fuel line after sitting for a while...and I am sure the injector O rings were an issue as well.
Since August, I have had no cold start issues, and matter fact, starts up better than it ever had before, instantly.
iggi
18
Feb 9, 2026 01:00 AM
Melvinyip
Apr 17, 2020 09:28 AM
TREX
Nov 2, 2019 07:31 PM
alistaircookie
Oct 8, 2015 10:52 AM
tippin
Aug 5, 2015 08:43 AM
