map/baro circuit high input Check Engine Light
Old Nov 11, 2009 | 03:25 PM
MRE7986's Avatar
MRE7986
Has anyone had this problem before.
Of course while I was accelorating after a toll booth to about 70mph the check engine light came on so I got home and got me scanner out, but batteries were dead so started the car got batteries then got home and check engine light was off. Plugged scanner in and this came up. map/baro circuit high input. Talked to dealer ship and they said could be intake leak (which I have) or other problems also they said it will not hurt the engine.
I was wondering if anyone else has had this happen and what it could be.
Old Nov 24, 2009 | 09:28 AM
MRE7986's Avatar
MRE7986
Update on problem.
Has not had the problem for awhile know and still have not fixed my intake tube.
Has anyone else have this problem before?
Old Nov 24, 2009 | 09:45 AM
jasonsmf's Avatar
jasonsmf
I had this same code, along with occasionally "map/baro circuit high input during deceleration"....the car would run terrible at part throttle, but OK when wide open.
I could go close to a week with no problem, SES light would go out, things would be fine.....then it would come back. I finally was able to monitor the MAP signal when it threw the code, it was essentially stuck at 229 kPa no matter what I was doing (idle, cruise, acceleration, etc..). My guess was that the TMAP sensor was dead. I replaced the TMAP sensor (thanks to Classic and the NAM discount!), so far this appears to have fixed the problem for me.
Jason
Old Nov 26, 2009 | 08:31 AM
MRE7986's Avatar
MRE7986
Thanks for the help I will keep an eye on it. Its weird how nothing changed when the light went on. It drove like it normally would still has not happened again
R60abq
R60/R61 Stock Problems/Issues
Jun 6, 2017 05:15 PM
Mini Cooper r56 Pr
Aug 12, 2015 07:42 PM
truedrew
Aug 10, 2015 10:39 AM
Lt. Dan
Aug 10, 2015 08:23 AM
