Suspension Wheel Spacer Question
Old Nov 10, 2009 | 06:53 PM
wzabrouski's Avatar
wzabrouski
If I wanted to push the stance on an r53 with stock s-lites with 205/45's what size spacer would I use. I am running about -2 camber up front and -1.5 in the rear with h-sport springs and koni yellows. Thanks for your help, Walter
Old Nov 14, 2009 | 04:57 PM
MINICHEF's Avatar
MINICHEF
Whatever fits. Measure the amount of clearance you have and go from there. I am running Koni Yellows with their sport springs for abot -1.5 over stock and run 215/45-17 tires with 5mm spacers. no rubbing
A lot has to do with rim offset
Old Nov 15, 2009 | 12:39 AM
nabeshin's Avatar
nabeshin
Functioning Lunatic
I use 5mm spacers with longer bolts. My alignment is the same as yours, but I'm on stock springs and dampeners. I have used 5mm spacers with s-lites, as well as my steel rims and 15" hollies.
G1HQ
Dec 7, 2015 02:23 PM
Mini'mon
Aug 16, 2015 04:15 PM
Rennfahrer555
Aug 13, 2015 09:07 AM
ki7hy
Aug 12, 2015 07:07 PM
ti22fjc
Aug 9, 2015 05:49 PM
