Navigation & Audio Front Speaker Replacement / Amp Question
Old Oct 17, 2009 | 11:45 AM
Wake|MCS's Avatar
Wake|MCS
#2: It's time to replace the front speakers as I have a blown tweeter and a blown mid (different doors). I was thinking about the Polk DB6561 as I've read good reviews and they can be had for about $115, anyone have any experience with these components? Any other suggestions?
I currently run a 500w 2-ch amp to power a 10" Kappa sub-woofer, I don't care for a lot of power to the sub as I'm over the heavy bass phase (when I put turn it up, it HITS). Could I do the following: power both front speakers off 1-ch (can run 125w continuous per channel at 4 ohms) and then power the sub off the other channel?
Please note, I'm on a very tight budget so keep that in mind.
Old Oct 17, 2009 | 07:15 PM
Wake|MCS's Avatar
Wake|MCS
Bueller... ? Bueller... ?
Old Oct 18, 2009 | 09:19 AM
Supercoop55's Avatar
Supercoop55
Options
Running the left and right fronts off of one channel would be a bad idea. You would only be getting half of the musical info in a track, especially on broadcasts/recordings that have good stereo seperation of instruments and vocals. The way around that would be to combine your stereo output to a mono input. You would get all the info, but it would sound flat an awful. There is one possible way to do as you propose. It requires passive crossovers. You can run your amp bridged and stereo at the same time if you passively crossover your fronts above what you crossover your sub at. For example; you run your amp full range. On the speaker outputs you run a high pass crossover on the left and right channels at, say, 80hz. At the same time you wire a single 80hz low pass crossover to your bridged output (usually right negative and left possitive, check your manual). This effectively divides up what the amp is "seeing" at it's output in a way that does not conflict. It's an old school solution, but it works for a budget. Note, you will not be able to independantly control your sub volume without a attenuator after the amp
silence2-38554
Nov 12, 2015 09:39 AM
squawSkiBum
Oct 2, 2015 09:21 AM
Minibeagle
Aug 13, 2015 10:00 AM
Lee-Oh_825
Aug 11, 2015 10:27 PM
OutMotoring
Aug 6, 2015 09:32 AM
