Servicing Cooper S Supercharger Oil
Old Oct 14, 2009 | 05:35 AM
fnc's Avatar
fnc
Found this article very helpful as per servicing oil in supercharger.
2002-2006 MINI Cooper S Supercharger Oil Service https://wiki.bentleypublishers.com/x/AgDsAQ
It might answer questions about servicing the oil. I know the topic pops up from time to time.
Old Oct 14, 2009 | 07:31 AM
miniconcarne's Avatar
miniconcarne
Nice! I wish the rear res. was as easy as the front!
Old Oct 14, 2009 | 07:36 AM
fnc's Avatar
fnc
It's not that the rear is hard.... it just takes forever!!!
Old Oct 14, 2009 | 08:31 AM
JAB 67's Avatar
JAB 67
Is it really a 3/16" allen wrench, or a 5 mm?
Old Oct 14, 2009 | 08:36 AM
fnc's Avatar
fnc
3/16 fits perfect, in my experience. 5 mm is a tad larger than 3/16, I think about 0.1 mm.
Old Oct 14, 2009 | 02:47 PM
apexer's Avatar
apexer
OK. Here is a stupid question (not my first). Since the front is so easy to check, if the oil level is OK there, what are the odds that the rear is also OK?
Old Oct 14, 2009 | 03:12 PM
Cadenza's Avatar
Cadenza
What do you need to remove to check the rear fluid level?
Old Oct 14, 2009 | 03:54 PM
fnc's Avatar
fnc
The rear resrvoir is usually the low one, and the PTO in the back is what fails most. The extra heat in the back must have something to do with the oil burning up.
Old Oct 14, 2009 | 05:04 PM
apexer's Avatar
apexer
Yeh, thats what I figured. Thanks for the quick reply
Old Oct 15, 2009 | 09:20 AM
IanF's Avatar
IanF
The water pump... which is fairly well buried on the engine... Like posted above, not terribly difficult, but it takes awhile...
Old Oct 15, 2009 | 12:04 PM
Cadenza's Avatar
Cadenza
I take it the coolant must be drained?
Old Oct 15, 2009 | 03:36 PM
nabeshin's Avatar
nabeshin
Functioning Lunatic
I really hope the s/c can come out without draining the coolant. I'm going to have to change the fluid in mine soon, and I want to open the cover and inspect the gears.
Old Oct 15, 2009 | 07:36 PM
AutoXCooper.com's Avatar
AutoXCooper.com
The SC can be removed without draining the coolant, it's tricky but we have done it, most time we don't because getting the SC off is easier then getting it back on with the water pump still in the car. Plus it never hurts to flush that system too.
We only do SC oil service out of the car to make sure we get 6 ounces in the front/pulley end and 3 or 4 ounces in the PTO. This also allows us to really test, look and scope the gut's without taking the whole thing apart.
Plus if it's not leaking or making noise we see no reason take apart a low mile (less then 75K) SC for just an oil service.
Old Oct 15, 2009 | 08:37 PM
nabeshin's Avatar
nabeshin
Functioning Lunatic
Good to know. Thing is I just had the coolant flushed out this summer.
Old May 29, 2010 | 10:35 PM
wrh3's Avatar
wrh3
minicoclub
Nov 11, 2015 07:25 AM
tr3y003
Oct 22, 2015 10:48 AM
minicoclub
Aug 25, 2015 09:07 AM
ludedude
Aug 10, 2015 07:16 PM
