R56 Coolant under CAI
Old Oct 11, 2009 | 07:26 AM
guitfiddler's Avatar
guitfiddler
Coolant under CAI
I noticed a collection of coolant under my Alta cai. My coolant level is low in the tank also. I can only guess that it is coming out of the cai. Does the coolant cool the turbo and some how come out with the blowoff? Is this normal? Or a sign of a problem?
Old Oct 11, 2009 | 09:12 AM
pilotart's Avatar
pilotart
Yes, it cools the Turbo and No, it should not leak.
Hose or coolant line would be first suspect.
Old Oct 11, 2009 | 12:20 PM
pillar's Avatar
pillar
i may be having the same problem... my stock boost tubes keep slipping off and i cant tell if its oil or coolant.
ive cleaned the boost tube with brakekleen multplie times (every 100ish miles) and something conitues to pool around the turbo...
coolant levels are kinda low but still in acceptable amount.... any ideas as to how to tell between some oil vs coolant?
Old Oct 11, 2009 | 03:17 PM
pilotart's Avatar
pilotart
Squirt a little water on the spot, if it's oil, it will bead and if it's coolant it will mix.
Steffen.Johnson
42
Jan 25, 2023 02:47 PM
simo711
Oct 8, 2015 07:07 PM
pglgp1292
GP Talk (2006)
Oct 2, 2015 10:34 AM
point665
Sep 29, 2015 12:41 PM
silence2-38554
Sep 28, 2015 12:19 PM
