Solo new v710 size 215/45r16 =bad
Old Oct 3, 2009 | 06:23 AM
grodenglaive's Avatar
grodenglaive
Kumho V710 215/45r16
Do not get these unless you have camber plates. They have square shoulders and are meant for cars with camber.
Previously I had run 215/40r16 in the v710 (round shoulders) and they were great, although quite a bit shorter than stock. I figured the bigger diameter of the 45 would give better top end and less wheel spin (R56). Big mistake: they wore very unevenly compared to the 40 series and were corded after only 8 events. They also felt like crap for the 1st couple events until the square shoulders rouned off. I did get less wheelspin on corner exit and hit the rev limiter less often, but the trade off was definitely not worth it. Also they are heavier than the 40r16.
Old Oct 3, 2009 | 09:59 AM
L8Apex's Avatar
L8Apex
I was kinda wondering about the squared shoulders. I thought they might have been for more stock class cars with less camber. Sucks that you had to go through that learning experience, but thanks for the info.
Old Oct 5, 2009 | 08:43 AM
RedSkunk's Avatar
RedSkunk
8 events?? From your post I'm assuming you're running stock camber and they corded on the outside?
I just finished my second full season on the 215/40 V710s. One tire is showing patches of a suspicious cordy layer underneath, but they wore phenomenally even - with a buncha (-2.3) camber.
Old Oct 5, 2009 | 09:59 AM
grodenglaive
That's right, stock camber and corded on the outside. Yeah the 215/40 size last way longer. The 215/45 ones might work okay with camber plates, but I was so dissapointed I would not try them again even if I had -3° camber. Well... maybe if they were 1/2 price.
Old Sep 12, 2010 | 05:48 PM
MotorMouth's Avatar
MotorMouth
After almost a full season my 215/40 had barely reached the wear bars. I'd say those were realty good. Was running ~2.5 camber. I like the lower profile of the 40s over the 45s anyway.
edit
aww crud.. great way to pay attention to the last post date.. I've created a zombie.
patsum
26
May 29, 2021 06:29 PM
riff42
Sep 22, 2015 03:07 PM
Rainforest_Elf
Sep 16, 2015 10:13 AM
R3411y
Sep 11, 2015 03:38 PM
