R50/53 All-Season vs. Performance Run-Flats on MCS?
Old Sep 23, 2002 | 06:35 AM
jcallen's Avatar
jcallen
Does anyone have any opinions of the All-Season Run-Flats versus the Performance Run-Flats on the MCS Sport Package.
I may have found a MCS to buy. The only difference that I have found is that the available car has the AS tires vs. the Performance that I was going to order.
Old Sep 23, 2002 | 09:28 AM
skain's Avatar
skain
>>Thanks
I've got the 17" All Seasons and they seem to stick to the road just fine. I test drove a car with the performance tires and really couldn't tell the difference. But maybe you're a more hardcore driver than I.
Old Sep 23, 2002 | 02:00 PM
Lenny's Avatar
Lenny
Just a note. I got a screw in my runflats ..by the way they work great. I had no idea.
The manual says it cannot be patched but my mini dealer called Goodyear and they said no problem if you use a radial patch. I can't be plugged though
Old Sep 23, 2002 | 07:36 PM
DavidG's Avatar
DavidG
>>Thanks
Well, if you've FOUND a car, and the price is not several thousand over list, you could consider the cost of new tires (~$800?) a VERY cheap "entry ticket"! Plus, you're coming up on winter, and could motor around on the AS's while doing research on the alternatives. You might even decide on a set of "sport" wheels with higher performance rubber, and keep the AS wheels/tires for the winter.
Just an option! If everything else is OK in the car, I wouldn't let the tires stop me!
Kimolaoha
Jul 5, 2023 01:04 PM
Kimolaoha
Dec 5, 2020 09:32 PM
eatsleepautox
Oct 30, 2015 06:46 AM
minipopkart
Aug 13, 2015 05:22 AM
