R50/53 changing the air filter
Old Sep 28, 2009 | 03:00 PM
Parche's Avatar
Parche
I'm trying to figure out where the air filter goes.
Old Sep 28, 2009 | 04:05 PM
AutoXCooper.com's Avatar
AutoXCooper.com
What type and year is your MINI?
Old Sep 29, 2009 | 01:04 AM
Eric_Rowland's Avatar
Eric_Rowland
First, remove the suspension...
But seriously, if you have a 02-06 S model, on the right side of the engine (looking from the front) you'll see a big black box (with an 'oil recommendation' sticker on it), with two torx screws on either side of a 'corrugated' plastic hose. After loosening the screws, remove the positive terminal from its clip, then lift up and push forward and the back will release from tabs on the lower box. It takes a bit of effort to 'convince' the top to come out. The filter is under the top. It's yellow, and is likely a nasty brown/black on the bottom.
Old Sep 29, 2009 | 07:37 AM
Bigshot's Avatar
Bigshot
Would help if we knew year and model of you MINI.
Old Sep 29, 2009 | 07:45 AM
slocraiger's Avatar
slocraiger
cabin air filter or engine air filter?
silence2-38554
98
Sep 21, 2016 02:52 PM
theblackfalcon
Aug 26, 2015 09:18 AM
Beau B
12
Aug 24, 2015 01:50 PM
polotska
Aug 23, 2015 09:10 AM
Aug 21, 2015 08:44 AM
