R50/53 What mpg for an MCS?
Old Oct 29, 2003 | 05:34 AM
savage65's Avatar
savage65
Title says it all.
Old Oct 29, 2003 | 05:41 AM
mcs22004's Avatar
mcs22004
>>Title says it all.
My '04 is getting @19.
Old Oct 29, 2003 | 05:57 AM
Devilman's Avatar
Devilman
I've been averaging between 24 and 28.
Old Oct 29, 2003 | 06:01 AM
CooperBeagle's Avatar
CooperBeagle
For highway driving I'm getting 32mpg. ('02 with 31k miles).
But, in town... with lotsa stoplights... pretty girls to show off for... somewhat less.
God speed.
Old Oct 29, 2003 | 06:19 AM
RaceCarDriver's Avatar
RaceCarDriver
I'm averaging about 24mpg, but I drive the car hard and like to shift at the redline. You could easily average high 20's if you take it easy. But who wants to drive an MCS easy.
RaceCarDriver
Old Oct 29, 2003 | 06:31 AM
fryedaniel's Avatar
fryedaniel
My '03 gets 26 most of the time driving to and from work, the grocery store, etc. My one trip on the interstates a couple of weeks ago I got 34 over the course of about 1300 miles.
Dan
Old Oct 29, 2003 | 06:47 AM
MartyR's Avatar
MartyR
I get about 28 combined city/highway in my late '03. Driving pretty hard, 93 octane each gas-up.
Old Oct 29, 2003 | 06:56 AM
MG-BGT's Avatar
MG-BGT
My combined avg is about 28 mpg, for my 03 MCS with 23k mi, 16" RF tires.
City is mostly 24-26, but can be as low as 21-22 on spirited driving. Hwy is 30-32 mostly, but when eeking out every bit of fuel I've gotten mileage as high as 38 (ok, only once, not typical). Also noticed that AC reduces mpg by about 2-4 depending on conditions, and cruise control reduces by about 1-3 mpg, depending on how you drive. All of these are calculated values, as my OBC over-estimates by about 8-10%. Tire pressure (and size) makes a difference, but in my experience the biggest difference is how you drive.
Lowest I've ever gotten was on the track: 8mpg.
_________________
Celeste: 03 EB/W MCS, cold, premium, sports a la carte w. W16"V, Lapis, HK, Forge coolant tank, saddlebags, interior trim in EB, euro shelf
Old Oct 29, 2003 | 07:03 AM
jurni's Avatar
jurni
>>Title says it all.
This past weekeknd we drove Boston to New York & got 31MPG avg speed 74MPH. On the way back we hit some traffic near the tapan Zee bridge (which counts for the slightly lower MPH) got 34MPG avg speed 70MPH I'm getting better Highway MPG in my MCS than on the '03 MC I traded in. Guessing it has to do with that 6th gear and the fact that I often drive over 80MPH.
I usually shift at 3000 RPMs but from time to time open up to 4500 or so.
In town, avg 17mph, I get 23MPG, About the same as in my '03 MC, though, if driving over 40 mph I drop the MCS into 5th gear (around 2000 RPMS)
I have an '04 MCS with 1500 & loving every mile! :smile:
_________________
'04 MCS DS/B PP,SP,CWP, HK, leather, Rear Fogs
Old Oct 29, 2003 | 08:28 AM
5280Motoring's Avatar
5280Motoring
On my mixed highway and city street commute, I'm hovering around 28 MPG. Open highway, I'm safely over 30 MPG. The MCS, she seems to like the altitude. I get nearly 34 MPG when I venture into the high country for scenic drives.
Old Oct 29, 2003 | 08:30 AM
C4's Avatar
C4
I am getting 22.8MPG in strict city driving.
Old Oct 29, 2003 | 09:23 AM
minihune's Avatar
minihune
OVERDRIVE - Racing Champion
Well there you have it, There is enough data above already given that ranges can be applied for MCS.
Given premium gas which will vary in octane from 91 to 93 octane
And add 2-4 mpg for using the AC depending on how much urban traffic there is.
Add 1-3 mpg for using the cruise control(from MG-BGT's comments)?
(This doesn't seem right, should be more like +0-1))
These are all calculated values from filling a tank of gas and driving then refilling.
Tire pressures do make a difference.
If driven as hard as you like expect
17 to 22mpg
In the city about 20-24 mpg.
On the hwy about 30-34 mpg with a high of up to 37 or 38.
In combined use 26-28 mpg
And now a word about mods:
When my 2003 MCS was more stock (madness intake only) (Also I always use premium gas and never run AC)I got
City and track days- 20 to 22 mpg
Best Hwy- 33-34 mpg
combined- easy consistent 28+ mpg
Now at 8000 miles with intake,61mm throttlebody, milltek header with wrap,quicksilver exhaust,pilo ignition upgrade with M7PB
and lightweight (36 pounds per corner) wheels at 33 psi each:
City 20 mpg
Hwy 29-30 mpg
combined 25-26+ mpg
I'll be adding pulley and ECU upgrades and that should help up to 2-3 mpg hopefully.
Moral of the story-
The MCS engine is efficient and the gearing is reasonable to expect as high as 34 to 38 mpg at best on the hwy yet it is prone to much lower gas mileage as low as 17-20 mpg with track driving or long periods of idling.
Given that the MCS can perform at extremely high levels this is quite a feat. Take another powerful car to the track and on the hwy and see what kind of numbers you can generate while having so much fun driving.
In today's very expensive climate for fuel I am glad that the MINI does so well and it's part at saving fuel. We could be all out there driving camaros and mustangs and getting 12 to 18 mpg.
Less wide (175) non runflat tires like 55 or 60 series tires will provide less rolling resistance and hence better gas mileage but what the hell- drive it like you stole it. (edited)
_________________
ALOHA
Old Oct 29, 2003 | 10:05 AM
telemarkjim's Avatar
telemarkjim
20-22 summer w/ac, 21-23 w/o, mixed highway and local (all roads treated as Motorspeedway).
Old Oct 29, 2003 | 10:17 AM
koolmini's Avatar
koolmini
better then my V8
Old Oct 29, 2003 | 10:21 AM
vdubdoug's Avatar
vdubdoug
28 to 32 on the highway around town and in traffic.
Old Oct 29, 2003 | 01:32 PM
MrWhoa's Avatar
MrWhoa
27.9 in town driving, with a good share of haul ***. 33-34 on the HWY.
Old Oct 29, 2003 | 02:43 PM
trailblazer's Avatar
trailblazer
I get around 20 mpg in the city, and 30 on the highway. Not that great, but at least I'm having fun!!!
Old Oct 29, 2003 | 02:51 PM
C4's Avatar
C4
My MCS only has 700 miles, so I expect the mileage to improve past the break in period. Oh and I use the A/C all the time (South Florida weather).
Old Oct 29, 2003 | 03:00 PM
Bk_MCS's Avatar
Bk_MCS
Someones probably already said it and I'll say it again, depends on how you drive.
When driven by me, read floored on take off 3200ish rpm cruise, my 04 with 2k miles gets 25 on a tank with a mix of floored acceleration and highway cruising. When on a trip I sat it under 3k in 6th gear and was getting 40s on the constant so I was probably getting well over 30 mpg and on the streets on the same trip I was getting 20ish, again, I drive it hard.
Old Oct 29, 2003 | 04:33 PM
Red's Avatar
Red
Around 28 mpg mixed around town and highway. I don't rev the snot out of it or floor it very often. Maybe once or twice a day.
But I am wearing the outside of my tires creating fun G forces!
Regards,
Red
Old Oct 29, 2003 | 07:52 PM
Bino's Avatar
Bino
My '03 MCS now has just over 9K miles on the clock. Overall average is 24.9 MPG. Worst tankful was 20.1, and best tankful was 28.0. I'm running on 17x7 S-lite wheels with 205/45 Pirelli Eufori@ run-flat tires. And my OBC is consistantly 3 to 4 MPG too optimistic.
Old Oct 30, 2003 | 04:54 AM
d-mini-ero's Avatar
d-mini-ero
26-32...as an average.
2002 MCS w/ 26K (powerchip ecu re-map, helix pulley, borla exhaust...and other stuff :smile
Peace,
D
Old Oct 30, 2003 | 09:57 AM
wwwebb's Avatar
wwwebb
Date Odometer Miles Gallons MPG
3/14/2003 326 312 11.241 27.76
3/17/2003 663 337 11.522 29.25
3/21/2003 1004 341 11.387 29.95
3/23/2003 1211 207 7.718 26.82
3/26/2003 1541 330 11.214 29.43
3/31/2003 1837 296 10.923 27.10
4/2/2003 2140 303 11.068 27.38
4/7/2003 2436 296 11.247 26.32
4/10/2003 2724 288 10.699 26.92
4/16/2003 3042 318 11.223 28.33
4/20/2003 3336 294 11.770 24.98
4/24/2003 3635 299 10.440 28.64
4/27/2003 3814 179 6.639 26.96
4/27/2003 3961 147 5.003 29.38
4/29/2003 4254 293 10.209 28.70
5/1/2003 4576 322 11.751 27.40
5/8/2003 4936 360 11.995 30.01
5/13/2003 5280 344 11.750 29.28
5/17/2003 5633 353 11.399 30.97
5/20/2003 5875 242 8.440 28.67
5/27/2003 6207 332 11.601 28.62
5/30/2003 6619 412 11.625 35.44
6/5/2003 6945 326 12.115 26.91
6/10/2003 7290 345 12.431 27.75
6/14/2003 7619 329 11.622 28.31
6/17/2003 7951 332 11.568 28.70
6/20/2003 8269 318 11.699 27.18
6/24/2003 8569 300 11.355 26.42
6/29/2003 8874 305 11.311 26.96
7/2/2003 9175 301 11.196 26.88
7/5/2003 9428 253 10.162 24.90
7/9/2003 9658 230 9.748 23.59
7/14/2003 9942 284 11.557 24.57
7/18/2003 10267 325 11.779 27.59
7/21/2003 10591 324 11.260 28.77
7/24/2003 10915 324 11.486 28.21
7/28/2003 11239 324 12.200 26.56
8/1/2003 11570 331 11.735 28.21
8/8/2003 11925 355 14.247 24.92
8/11/2003 12227 302 11.070 27.28
8/14/2003 12529 302 11.234 26.88
8/20/2003 12890 361 12.777 28.25
8/25/2003 13260 370 12.910 28.66
8/29/2003 13590 330 11.965 27.58
9/4/2003 13907 317 11.489 27.59
9/9/2003 14251 344 12.650 27.19
9/13/2003 14585 334 11.945 27.96
9/18/2003 14905 320 11.023 29.03
9/20/2003 15124 219 8.144 26.89
9/20/2003 15378 254 8.923 28.47
9/23/2003 15707 329 11.151 29.50
9/27/2003 16025 318 11.416 27.86
9/30/2003 16370 345 12.027 28.69
10/3/2003 16706 336 11.478 29.27
10/8/2003 17002 296 11.737 25.22
10/10/2003 17344 342 12.108 28.25
10/14/2003 17666 322 12.093 26.63
10/18/2003 17992 326 12.219 26.68
10/24/2003 18322 330 12.202 27.04
10/29/2003 18645 323 12.032 26.85
Start Date 3/11/2003
Fillups 60
Odo Start 14
Ttl Days 232
Ttl Miles 18631
Avg Miles 311
Ttl Gals 670.928
Avg Gals 11.18
Avg MPG 27.77
Ttl Amt $1,117.29
Avg $/Gal $1.67
Avg Fillup $18.62
Days/Tank 3.87
$/Day $4.82
$/Mile $0.060
m3ster's Avatar
m3ster
I picked up my MCS a little over a week ago and have put 500 miles on it. In those 500 miles I averaged 28.6 mpg. 300 miles are city miles and 200 miles are highway miles. Of course, this may not be a good indication of mpg because I have not taken it above 4000 rpm. I am sure that when the engine is broken in, my mpg will drop.
Old Oct 30, 2003 | 09:58 AM
wwwebb's Avatar
wwwebb
Oh yeah,
Pulley and Madness Intake
