Interior/Exterior S front bumper on Cooper
Old Sep 25, 2009 | 07:15 PM
putttn's Avatar
putttn
I have a Cooper and want to add the S bumper, which I also have. Is there anything special about attaching the S to th Cooper or is it pretty much the same?
Old Sep 25, 2009 | 07:35 PM
Partsman's Avatar
Partsman
Legion_of_Doom
I think the only thing you will need to do is relocate the fogs(if equipped) to the second set of holes.
Old Sep 25, 2009 | 09:02 PM
putttn's Avatar
putttn
I do have fogs....2nd set of holes??
Old Sep 26, 2009 | 12:58 AM
glnr13's Avatar
glnr13
there are 4 screws that hold the fogs in. remove the front portion of the wheel liners and bend them back to access the 4 screws. there are speed clips that are in those spots, remove them also and relocate them to the 4 holes just above and to the outside corners of the bumper carrier and reinstall the fog lights. then you can put in the s bumper.
when you take off the bumper this will all make sense. the relocation is only about 1 1/2" up and maybe 1" outwards.
Old Sep 27, 2009 | 07:09 PM
putttn's Avatar
putttn
There must be some kind of different connector for that front panel. I used a phillips head screwdriver to undo the fastener and buggered it up, am I missing something here?
Old Sep 27, 2009 | 08:26 PM
glnr13's Avatar
glnr13
for the bumper itself? those are torx head screws not Phillips, I hope you didn't strip them.
there are the 2 torx head screws you need to remove by the radiator, the 2 screws at the corners of the bumper accessed by the wheel well, the 2 plastic expansion rivets in the wells, then 2 more Phillips head screws from underneath and then 3 8mm head screws along that same strip.
Old Sep 27, 2009 | 09:13 PM
putttn's Avatar
putttn
Yup, I think I did. I'm talking about the inner wheel well panel on the front part of the panel just forward of the tire.
Old Sep 28, 2009 | 07:13 PM
chaseabryant's Avatar
chaseabryant
those screws that you are talking about are for the expanding rivets in that hold the wheel well liner in place. They like to spin if not held in place. Usually a flat head screwdriver works well in the little rectangular slots on either side of the "screw" head. Every once in a while a slight pry is necessary to get them off.
-Chase
dcrna1
Aug 19, 2015 01:30 PM
skippermini
Aug 12, 2015 10:05 PM
bleonard1401
Aug 4, 2015 09:39 PM
