R50/53 Wireing problems after I replaced Clutch
Old Sep 25, 2009 | 09:46 AM
diamondwon's Avatar
diamondwon
Hi All,
I recently pulled the motor from my 02 Cooper S, Electric Blue to replace the clutch. ( Pictures Attached )Before i could finish the job i had to have back surgery and didn't get to finish the job in a timely manner. I need to know where 2 wires connect. If someone would help me by looking at their Mini and tell me where these 2 wires connect. they are on the top of the motor and should be easy to find with minimal disassembly. This is my first time in this forum and I will be greatfull for all the help i can get.
Thanks,
Need to Motor
Attached Thumbnails Wireing problems after I replaced Clutch-pic-mini19.jpg   Wireing problems after I replaced Clutch-pic-0045.jpg   Wireing problems after I replaced Clutch-pic-0046.jpg
Old Sep 25, 2009 | 11:18 AM
healey67's Avatar
healey67
Well thanks for the pictures... but I think pictures of the wires you are trying to find a home for might have been more helpful in assisting you?? Try to get a picture of those and we can help you out I'm sure.
Old Sep 25, 2009 | 03:11 PM
diamondwon's Avatar
diamondwon
Was trying to save time.
Was tring to find some one helpfull first. A lot od info to reveal more than once. And thanks for the assistants. I'll get those pictures posted tonight.
Old Sep 25, 2009 | 08:42 PM
diamondwon's Avatar
diamondwon
Pics of the wires
Ok, here are some pics of the wires. One of the wires comes from the bundle at the top of the trasmision bell housing. It is the last pair of conductors at the back side of a bundle. Two conductors with a modular plug. The colors are Blue with a Yellow stripe and Green with a Purple stripe The other is a single conductor that comes up from the power steering pump and is bundled with a wire that connects at the bottom of the fuse panel in the engine compartment. Both are red, one has a modular connector that attaches to the fuse panel. The other is a round connector with a hole in the center so it can be attached with a screw or nut on a bolt. in the second pic i marked the wires i need to know where they connect with a white tab. I hope this is clear enough.
Thanks for your help,
Need to Motor
Attached Thumbnails Wireing problems after I replaced Clutch-pic-0059.jpg   Wireing problems after I replaced Clutch-pic-0060.jpg
Old Sep 25, 2009 | 10:41 PM
desmo's Avatar
desmo
I believe the cable on the right, bolts to the frame below the fuse box. I don't remember if its a stud or a bolt. The conector doesn't look like any of the ones on my car that are visable but it only appears to have two wires and the only two wire connector I can think of goes to the power steering pump. If it is it will have some pretty large contacts in it.
Hope this helps
Old Sep 26, 2009 | 01:19 PM
healey67's Avatar
healey67
well in the 2nd picture.. the connector on the left appears to be the reverse light switch connector. it plugs in on the back side of the trans.
the cable on the right.. are you sure that both wires are RED coming from the power steering pump? One should be red and one Brown which is the ground that should go to the ground point under the fuse block.
Old Sep 28, 2009 | 04:22 PM
diamondwon's Avatar
diamondwon
Can any of you confirm these locations by looking at them on your vehicle? Could you please disassemble yours and take a picture? I can't afford to take a chance with the locations. Especially with the wire that comes from the power steering pump.
Thanks,
Need To Motor
Old Oct 1, 2009 | 09:17 AM
diamondwon's Avatar
diamondwon
You gy=uys were right! I found the backup light switch and the other wire from the PSP was brown. Very light brown. Well on my way to completeing the Clutch job. Thanks for the help!
Need To Motor
eliseo1981
Jan 28, 2021 02:45 PM
Zettinger
Aug 25, 2015 04:04 PM
PrimePower
Aug 16, 2015 06:29 PM
PSIChocolate
Aug 13, 2015 12:46 PM
Colt45Magnus
Aug 12, 2015 06:43 AM
