R50/53 A question of thixotropy
Old Sep 20, 2009 | 08:00 AM
hegira's Avatar
hegira
So...
I did an oil and filter change on Emily ('02 MCS) the other day, and as I was adding the replacement oil, I started wondering; If I mix one part of 5W-30 with one part of 10W-40 (for example), do I obtain an end-result of a viscosity of 7.5W-35?
In other words, is the mixing of different viscosities linear?
I may have to much time on my hands.....
Old Sep 20, 2009 | 08:17 AM
cristo's Avatar
cristo
Alliance Member
It's probably not strictly linear, but I'll bet it's very close.
Old Sep 20, 2009 | 08:21 AM
ron-s mini's Avatar
ron-s mini
On this thread https://www.northamericanmotoring.co...h-pics-17.html -- (Post 416 by Investigator)
there is a link to a really good article that will tell you more than you want to know about oil.
Old Sep 20, 2009 | 03:18 PM
thecigarman's Avatar
thecigarman
Originally Posted by hegira
So...
The short answer is No, you will have oil that is 5W-40 (You are adding 5 weight and 40 weight that did not exist in each of the two components, respectively. The 5W-30 indicates the viscosity range from 5 W to 40 W).
BTW, my recollection of thixotropy form Geology class is that it refers to gels/semisolids that change viscosity upon agitation --like clays that become liquid in an earthquake.
Old Sep 21, 2009 | 04:58 AM
hegira's Avatar
hegira
"The short answer is No, you will have oil that is 5W-40 (You are adding 5 weight and 40 weight that did not exist in each of the two components, respectively. The 5W-30 indicates the viscosity range from 5 W to 40 W)."
Cigarman, that makes perfect sense! I didn't think it through far enough.
And as far as "thixotropy" goes, I was mistooken. I was referring to the study of viscosity and the resistance to shear in a liquid.
My bad.
Old Sep 22, 2009 | 07:02 AM
hegira's Avatar
hegira
The article Ron-s mini refers to (http://www.focfloridaregion.com/) should be required reading for anyone with an interest in engine oil perfomance. I've read it now a couple of times, and find it very enlightening.
Grizld700
Dec 30, 2015 10:47 AM
donniedarko
Oct 21, 2015 01:15 PM
twriter
Oct 2, 2015 03:14 PM
Carwash
Sep 15, 2015 02:02 AM
marc0011
Sep 10, 2015 10:04 PM
