Navigation & Audio Confusion Abounds
Old Sep 20, 2009 | 05:03 AM
Frank in Toledo's Avatar
Frank in Toledo
Confusion Abounds
Recently I bought and installed a Sirius Starmate 5 in my 2004 Cooper S with the H/K radio system. It soon became apparent that using the supplied FEA is not the best, so decided to get an FM Direct Adapter. Then the more I read here I see references to AUX plug on the H/K radio, and it might be hidden somewhere. I have not been able to find it.
Is there an AUX connector on my radio or not and where is it? I am going to have to pull the radio to hook up the FM Direct Adapter anyway am I going to find the AUX plug?
Next Question: does the FM Direct Adapter go behind what is referred to as the Head Unit in the dash?
Last edited by Frank in Toledo; Sep 20, 2009 at 05:20 AM. Reason: Added another question.
Old Sep 20, 2009 | 05:24 PM
ppro's Avatar
ppro
Look Here
I just installed the Auxiliary Audio Input. It was a single wire with a plug on one end that goes into the back of the radio. I simply removed the panel under the steering wheel, and the left upright next to the radio. The write-up is on my web site. The only other thing I removed was the glove box (5 screws) and made the hole for mounting the input. Then I put the glove box, upright, and panel under the steering wheel back together. 30 minutes.
Then I installed XM radio and iPOd and a few other things. They plug into the Aux Audio input. No FM Modulation here...
Click the picture for the write-up.
Old Sep 20, 2009 | 06:46 PM
Frank in Toledo
Thanks for your excellent reply. Question: Does having the OEM navigation system effect this installation?
Old Sep 20, 2009 | 07:03 PM
ppro's Avatar
ppro
It may - if there's something already plugged into the opening for the AUX then the wires need to be moved the socket that comes with the AUX.
Honestly, I would have a hard time without the factory service manual (TIS)
There's a lot of if's ands and buts with these cars.
Old Sep 21, 2009 | 02:56 PM
Eric_Rowland's Avatar
Eric_Rowland
Yes, the factory Nav uses a plug which encompasses the Aux-in pin. As ppro said, you just have to pull the connector from the aux-in and insert into the Nav connector. Great Bear has a writeup on it somewhere around here...
Old Sep 23, 2009 | 09:19 AM
Frank in Toledo
Thanks to All who helped
Your help and advice was very valuable and made my job of installing a FM Direct Adapter very easy. The Sirius radio now works great with no static and better volume.
Thanks again for all your assistance.
Last edited by Frank in Toledo; Sep 23, 2009 at 09:21 AM. Reason: Added necessary words.
Old Oct 1, 2009 | 10:55 AM
ppro's Avatar
ppro
Did you install the Aux Audio Input? What's the FM Direct Adapter?
Old Oct 7, 2009 | 07:34 PM
Minipapa's Avatar
Minipapa
I have 05 Mini with factory Nav. Installed the auxiliary per diagram in pins 3, 4 and 10, with the Nav in pins 2, 8, and 9. However, the factory radio does not recognize auxilary so I can't play my iPod. Has anyone run into this issue or know the solution? Thanks...
Old Oct 7, 2009 | 07:37 PM
Minipapa's Avatar
Minipapa
Never mind - had the CD changer plug!
Old Oct 8, 2009 | 02:49 PM
ppro's Avatar
ppro
6-CD Changer
Do you mean that because you have the 6-CD changer, you cannot use the Aux Audio Input?
Here's a drawing showing the pin out on the connector.
2011minnie
Tires, Wheels, & Brakes
Dec 10, 2015 10:36 AM
OutMotoring
Nov 16, 2015 07:04 AM
pglgp1292
GP Talk (2006)
Oct 2, 2015 10:34 AM
milkrun49
Sep 28, 2015 12:03 PM
JMF1975
Sep 11, 2015 03:29 PM
