R56 Air Box Inlet Tube Re-Install?
Old Sep 16, 2009 | 01:33 PM
Dwight Walhood's Avatar
Dwight Walhood
After much pain and cursing, I got the inlet tube off so I could wrap it in thermal reflective tape. I've run out of bad words trying to re-install and have it stay put on the air box end. Is there some trick, or do I have to pull off the top of the air box to have room? Along with the O-ring seal, it appears to have a bayonet lock on it. Need help as the blood trail is getting grim.
Old Sep 16, 2009 | 02:01 PM
iwashmycar's Avatar
iwashmycar
i think it might be easier to just take the air box out and install it as one?
Ive only ripped mine out lol. Its like one screw and it tilts out of rubber grommets.
I think it does sort of a twist-in-and-lock action?
dont remember too well, but like i said, i'd take the air box out
i assume its the 6 to7 part
Old Sep 16, 2009 | 02:51 PM
slinger688's Avatar
slinger688
Dwight,
Refering to the diagram posted, are you taliking about part 7/8 or part 10?
If it is part 7/8, just tilt the airbox forward, fit the tube in and tilt it back to lock, just like iwash mentioned.
Old Sep 16, 2009 | 03:02 PM
Dwight Walhood
Reluctant Blood Donor
Thanks Buckets! Sort of suspected I'd have to pull the air box to get at it. Got caught being lazy. That diagram is worth it's weight! Where'd you get it? Along with the air box, I'll have to pull the STB. Oh well, time to give blood again.
Pale Dwight
Old Sep 16, 2009 | 03:06 PM
Dwight Walhood
Originally Posted by slinger688
Dwight,
Nope, it's parts 6-7. Thanks anyhow. DW
Old Sep 16, 2009 | 03:16 PM
ALTA_Jarid's Avatar
ALTA_Jarid
Looks like a picture from realoem dot com!
Old Sep 17, 2009 | 02:35 PM
jbewley's Avatar
jbewley
Part 7 goes into part 6 using bayonet fittings. hold the long end up at about 45 degrees and then angle it toward the fender. Slip the back in, bring it back square and twist it down. It is tight, but should go right in.
Jim
Old Sep 22, 2009 | 08:13 PM
Dwight Walhood
Air Intake Tube Re-Installed
Finally got the damn thing back on. Only moderate blood loss, but still feeling a little faint. Anybody B Negative? Thanks for the help guys, I'll think long and hard before I pull that sucker again!
Old Sep 23, 2009 | 08:38 AM
iwashmycar's Avatar
iwashmycar
yeah realoem.com has all of those... takes some searching but its a great resource
cerenkov
Apr 24, 2018 07:47 AM
The_Kid
Aug 28, 2015 04:50 AM
Aug 27, 2015 03:18 PM
mikeyb74
Aug 24, 2015 12:13 PM
M7Speed
Aug 6, 2015 01:48 PM
