R56 Auto recirc button
Old Sep 7, 2009 | 07:38 PM
kavatski's Avatar
kavatski
Auto recirc button
Searched on this but came up blank.
The last MCS loaner I drove (built 11/08) had the auto recirc mode for the automatic climate control (small "A" on the recirc button). This mode apparently switches back and forth between recirc and fresh air on its own based on input from a sensor. Sounds good.
However, the new MCS that I picked up last week (built 06/09) does NOT have this automatic recirc mode (yes, it has the auto climate control). The recirc button doesn't have the "A" on it and pushing the button just toggles between manual recirc and fresh air. My printed owner's manual doesn't make mention of the auto recirc feature, although the older 2009 PDF version of the manual does.
Looks like the auto recirc got canned sometime during the 2009 production year. Anyone know why?
Old Sep 7, 2009 | 07:56 PM
malteseracer's Avatar
malteseracer
Is that what that button does?
Old Sep 7, 2009 | 07:58 PM
Benibiker's Avatar
Benibiker
My 08 goes from recirc to fresh air about every 30 min when te recirc button is selected. The owner's manual confirms this. Have you driven it long enough to notice if it switches over?
Old Sep 8, 2009 | 05:54 AM
kavatski's Avatar
kavatski
I've driven it a while but not on recirc mode, so haven't noticed that. I wouldn't generally make much use of recirc, so that's why the auto recirc (Mini/BMW calls it AUC) sounded useful. Recirc only when you need it.
But for some reason they removed it. Could be for cost savings, but seems odd to drop it in the middle of a model year.
Old Sep 8, 2009 | 10:55 AM
Benibiker's Avatar
Benibiker
I suspect if you select recirc you'll nontice it'll switch to fresh air every so often.
Old Sep 8, 2009 | 11:22 AM
kavatski's Avatar
kavatski
Could be, but that would be the opposite of the AUC mode, where it runs in fresh air and switches to recirc as needed.
Maybe I'm the first one to notice that it's gone on the late '09 builds...
Old Sep 8, 2009 | 10:32 PM
Benibiker's Avatar
Benibiker
When I put my in fresh it stays fresh, when I put it in recirculate it cycles from recirculate to fresh about every 30 minutes. Guess they got rid of it on 09s then...
Old Sep 9, 2009 | 06:10 AM
kavatski's Avatar
kavatski
Right, and the AUC gives you a third mode - fresh, recirc and auto recirc. That last mode is the one that seems to have been dropped partway through 2009.
Old Sep 9, 2009 | 11:58 AM
MINIxB's Avatar
MINIxB
My 09 Mini has the auto a/c and the auto recirc...if you keep pressing the button you can switch it to always on recirc or fresh air...
Old Sep 9, 2009 | 02:53 PM
kavatski's Avatar
kavatski
Yup, that's the one. Earlier '09s seem to have it, later '09s don't.
Old Sep 9, 2009 | 03:25 PM
brightwhite's Avatar
brightwhite
Not sure when my 09 MCS was built, but it does have it. It's a Canadian model though, if that changes anything.
Old Sep 10, 2009 | 02:58 AM
Oakland Raiders Mini's Avatar
Any pictures of this button?
Old Sep 10, 2009 | 08:03 PM
pilotart's Avatar
pilotart
Link to open photo in its own tab/window
After opening photo, click on it to enlarge and see details.
First press of the button below AUTO places a red icon in the 'Two-O'Clock' portion of the round display, including the 'A' with the little MINI and its 'inside-air' arrow.
A second push of the same button removes the 'A' from the icon.
I have not noticed any change in the air output or sound when the button is pushed, perhaps I did not wait long enough.
Thirty years ago, all Auto AC Systems only allowed 'Re-Circulate' mode on MAX COLD setting, the thought was that you needed fresh air entering cabin most of the time.
This requirement seemed to go away with the "wouldn't start until seatbelt inserted" feature.
I have encountered modern autos that worked the same way on AC Recirculate.
Old Sep 10, 2009 | 08:14 PM
kavatski's Avatar
kavatski
That's the one. My '09 MCS does not have the "A" on the button and there are only two modes: recirc or fresh. The earlier-build '09 MCS I drove right before getting mine did have the "A" button.
I'll see if I can get an answer out of the dealer or ask them to go back up the chain of command and find out why they took it out - if it was simply to save a few bucks or something else.
Doc Pain
Mar 10, 2021 04:50 AM
Peking Duck
Jan 19, 2021 03:17 AM
gar56
Nov 15, 2016 06:41 AM
krohm
Sep 28, 2015 12:16 PM
kevinlhr310
Sep 27, 2015 02:31 PM
