R50/53 How to reset brake caliper?????
Old Sep 5, 2009 | 03:12 PM
Pinball Rick's Avatar
Pinball Rick
I have a 2004 Cooper S and I need to know how to recompress the rear brake calipers. Thanks for any advice.
Old Sep 5, 2009 | 03:55 PM
asthmatic's Avatar
asthmatic
uncompress? I use a c-clamp to make clearance for the new break pads. is this what you are talking about? or are you trying to remove your caliper from the worn out rotors, so you can replace the pads?
Old Sep 5, 2009 | 04:08 PM
AstroBlackS's Avatar
AstroBlackS
Use a "crow's foot" brake tool. It's the easiest way.
Essentially you need to rotate and "recompress" at the same time.
Something like this: http://www.denlorstools.com/home/dt1..._kd_41540.html
Old Sep 5, 2009 | 04:28 PM
ron-s mini's Avatar
ron-s mini
This post is a good one on gen1 rear brakes.
https://www.northamericanmotoring.co...beginners.html
Old Sep 5, 2009 | 05:01 PM
MINIdave's Avatar
MINIdave
You need this tool set, harbor Freight has it for $20, a worthwhile investment.....
Available here......
http://http://www.harborfreight.com/...emnumber=40732
Old Sep 5, 2009 | 05:36 PM
moreorless's Avatar
moreorless
A "C" clamp to
compress, while at the same time either needle nose pliers or channel locks to ROTATE.
Old Sep 6, 2009 | 07:12 AM
Pinball Rick
Many Thanks
Just a quick note to say thanks to all that replied. I got the job done, thanks to all of your quick replies.
Pinball Rick
Old Sep 6, 2009 | 07:38 AM
asthmatic's Avatar
asthmatic
so what were you trying to do and whos method worked?
Tinklespout
16
Sep 6, 2015 11:39 AM
PelicanParts.com
Tires, Wheels & Brakes
Sep 3, 2015 03:22 PM
squawSkiBum
Sep 2, 2015 09:56 PM
Ntety
Sep 2, 2015 08:39 PM
elightbo
Tires, Wheels, & Brakes
Sep 2, 2015 08:17 AM
