PCV valve CHANGED? When?
Old Sep 1, 2009 | 04:59 PM
pizmo pete's Avatar
pizmo pete
I recently replaced my valve cover with a used cover I got at the NAM Marketplace, Thanks Thumper, and in the 2002 year the PCV valves had o-ring and was secured with 8mm bolt. The new cover has no bolt hole and a brass female bushing with internal threads. Does anyone know what year they changed the cover and PCV valve? Real OEM shows only the first one in the diagrams and I got to be sure what part number goes with this new valve. There are 3 of them... Of course the stealer doesn't have the part in stock and if i want it I'd have to "prepay" $39.00 first. WTF Searched online found one for $20 but no photo?Arg?!!# Help!
Old Sep 1, 2009 | 08:28 PM
-=gRaY rAvEn=-'s Avatar
-=gRaY rAvEn=-
Moderator
Me thinks the 20 dollar one's are for the 02-04 models... secures with a bolt.
The others even sound more expensive....
Have you checked www.realoem.com for the part No. ?
Old Sep 2, 2009 | 02:09 PM
pizmo pete's Avatar
pizmo pete
Yes real oem shows only the bolted one and of course no picture for the 2 other PCV valves. Maybe someone has seen the part but it has to be newer because I have a 2002 and 2006 and neither had the valve without the bolt.
Old Mar 15, 2010 | 10:00 AM
knotcher's Avatar
knotcher
i too have the threaded pcv valve rather than the one secured with a bolt...which i just snapped off this weekend. anyone know what the correct part number is for the screw-type?
realoem lists 11127513082 but if a call to pelicanparts and i was told that it is supersceded by 11127577568. on rmeuropean, neither of those parts are listed, but if i drill through the options for an 05 MCS, i get part number 11127829990.
so which one is it???
Old Mar 15, 2010 | 12:12 PM
MINIsurf's Avatar
MINIsurf
How often should the PCV be changed, I just had the /valve cover gasket changed and I didnt even think about the PCV.
Old Mar 15, 2010 | 12:25 PM
knotcher's Avatar
knotcher
it's not a wear item and doesn't need replacing, unless you break it like i did...now i just need to figure out what part to order!!!!
Old Mar 15, 2010 | 01:13 PM
mikenacarato's Avatar
mikenacarato
if you take the pcv valve off and shake it and hear no clicking sound..replace it because its stopped up.
Old Mar 17, 2010 | 07:01 PM
pizmo pete's Avatar
pizmo pete
pvc
Gee I think thru the bag out,,,it was a late 2007 s/c version possibly 2008 conv. but I think it was the newest. I'll check my workbench tomorrow and post again.
HaveATank
Aug 24, 2015 10:26 AM
sprp85
Aug 22, 2015 06:16 AM
Lex2008
Aug 16, 2015 08:33 PM
FLYM1N1
Aug 16, 2015 01:17 PM
