Help! Front brake line blew and oem part not available
Old Aug 15, 2009 | 07:45 AM
Galaxie500's Avatar
Galaxie500
I'm stuck in a town on a cross-country trip and the front brake line blew. no shop anywhere nearby stocks the MINI part (no surprise). Anyone have any ideas for another more common brake line i could use as a temporary solution?? all help appreciated.
Old Aug 15, 2009 | 09:52 AM
moreorless's Avatar
moreorless
If the push comes to the shove you could always use your emergency brake to get you to where you're going or to a dealer.
Old Aug 15, 2009 | 10:05 AM
buzzsaw's Avatar
buzzsaw
Autozone and O'Reilly's carry them. If they are in your area might be worth a try. Good luck.
Old Aug 15, 2009 | 01:09 PM
Tio Barry's Avatar
Tio Barry
If it is the flex line that blew you could clamp off the hose, blreed the three remaining and drive almost normally to civilisation.
Old Aug 15, 2009 | 03:52 PM
nabeshin's Avatar
nabeshin
Functioning Lunatic
Just curious here, but how did you blow a brake line? Heat failure from mountain driving? Just a rare weak OEM brakeline?
Old Aug 16, 2009 | 01:10 PM
AutoXCooper.com's Avatar
AutoXCooper.com
please don't do that if you have a clutch. The brake and clutch use the same system and you don't need to risk more damage. Plus the E-brake would not be a safe way to go.
Old Aug 17, 2009 | 10:37 AM
herbie hind's Avatar
herbie hind
prolly too late but why not find something close to stock and put it on temp .?
Old Aug 17, 2009 | 06:57 PM
MINIGURU@WAY MOTOR WORKS's Avatar
Vendor
If you still need it I could overnight you one, but prob too late now.
www.WayMotorWorks.com 2006 & 2007 NAMCC Overall Champion
Alta,M7,Helix,Wilwood,H-sport,Milltek,CROSS,Craven,DDM,H&R,Megan,Carbotech,EBC,Forge,TSW,Powerflex
minimofo
Apr 4, 2016 07:36 PM
Dashdog
Aug 10, 2015 06:17 AM
StealthR53
Aug 8, 2015 10:59 AM
