Solo Tech Inspection
Old Aug 1, 2009 | 05:03 PM
minigirl78's Avatar
minigirl78
Tech Inspection
So, I'm pretty new to the whole autocross thing, and I totally love it! But I have a question...so far before every event I've emptied out my glove box. Do I really need to do this to pass tech? Or can I leave stuff in there as long as everything else is out of the car?
Thanks everyone! See you out there!
Old Aug 1, 2009 | 05:42 PM
dogdal24's Avatar
dogdal24
Good question and timely too! We are about to go to our 1st autocross tomorrow. I didn't think the glove box needed to be emptied but would like to know for sure also.
Old Aug 1, 2009 | 09:20 PM
veggivet's Avatar
veggivet
Not sure about autocross, but I know they want it emptied for track days.
Old Aug 2, 2009 | 05:57 AM
STLMINI's Avatar
STLMINI
I empty it on track days. Don't know about auto cross but I would think you would want it empty also. You don't want things moving around possibly flying out if the glove box accidentally opens or is opened because of an accident.
Old Aug 2, 2009 | 11:45 AM
Dinosaur's Avatar
Dinosaur
I've tech'ed a few car for autocrosses and I can tell you it is a "safety" inspection only. I have never looked in someones glovebox, I will ask that you remove anything loose in the cabin, coolers, tools, toys, anything that will become a flying object while on course. If you are worried about weight, then feel free to remove the pound or so you have in there, and you can remove the spare tire too, if you want to (and have one ). Unless your glove box pops open on its own I don't see a problem, I personally carry a fire extinguisher in the glove box of my RX7 when autocrossing and for track days, no one has ever made me remove it, no one has ever looked in there during tech either.
Old Aug 2, 2009 | 07:11 PM
dogdal24's Avatar
dogdal24
Just got done 1st autocross. It was awesome! And no they didn't even look in the glovebox.
Old Aug 4, 2009 | 03:53 PM
minigirl78's Avatar
minigirl78
Awesome! Thanks ...Glad I don't have to do that every weekend .
Old Aug 5, 2009 | 10:58 PM
MINIGURU@WAY MOTOR WORKS's Avatar
Vendor
The Tech inspections are more of safety inspections just to make sure general things are ok. You should be ok to leave stuff in the glovebox, but technically you are adding weight??
They normally don't go too deep on the inspection just cause if they do and something they really look at breaks they don't want to be liable. By someone saying they checked it and said it was ok and look it broke, it's SCCA's fault.
www.WayMotorWorks.com 2006 & 2007 NAMCC Overall Champion
Alta,M7,Helix,Wilwood,H-sport,Milltek,CROSS,Craven,DDM,H&R,Megan,Carbotech,EBC,Forge,TSW,Powerflex
Old Aug 6, 2009 | 12:53 PM
GOTCURVES's Avatar
GOTCURVES
First rule of tech inspection.
Have the car ready for inspection as if you were going out on course!!
The "hot spots" for inspection are the following;
remove floor mats
Battery secure
brake fluid level
no cords showing on tires
no loose body panels and trims
under the influence (yes I talk to you to see if there is any impairment)
correct helmet rating (if using your own)
no nitrous!
That's about it. If the car is trailered to an event I go alittle deeper by getting in and pushing the brake pedal, checking the seat mounting points, and restraints.
Old Aug 6, 2009 | 07:27 PM
MJCMini's Avatar
MJCMini
Add in to the list (at least in our region)
- Make sure there is not excessive play in the wheels
- Make sure that pedals - especially brakes appear to be functional and not overly loose.
- Make sure the car has functioning non-damaged seat belts or harness.
Papers and manuals in the glovebox are OK as long as the door shuts. Anything heavier/harder should probably be removed. As a competitor I can tell you are few things more unnerving than having an iPod or something slamming around inside the glovebox while you are trying to navigate a course.
From my standpoint when doing tech, I check all of those items and make sure that the car and driver appear safe to be in the event. Also, at regular regional events tech is also important to make sure you are in the correct open or pax class. As an entrant you should use your tech inspector to your advantage - make sure you get into the class where you will have the most opportunity to compete with like skilled drivers and cars.
Ultimately though, it is up to the entrant to know if their car is overall unsafe to drive and use proper judgement when preparing the car for the event.
One more note for Mini drivers to help things along, from past experience is make sure you have the bonnet and boot open for tech. Assume the individual doing tech has no idea your battery may be in the boot and that your hood release is on the passenger side.
Old Aug 19, 2009 | 02:16 PM
Gromit801's Avatar
Gromit801
remove floor mats
Battery secure
brake fluid level
no nitrous!
And no water spraying units attached to the intercooler.
Usually, they will ask you to pop the hood and the hatch, and leave your helmet on the seat. They'll do the rest.
I would clear out all the loose stuff, as it has a tendency of flying around and getting places you don't need it to be.
Steffen.Johnson
42
Jan 25, 2023 02:47 PM
gknorr
Dec 26, 2016 09:38 AM
vulkandino
Oct 31, 2015 08:29 PM
pkillur
Tires, Wheels, & Brakes
Oct 1, 2015 03:59 AM
gnhovis
Sep 28, 2015 10:56 AM
