No Air Conditioning - AC Light blinks when turned on?
Old Jul 27, 2009 | 01:50 PM
Creech's Avatar
Creech
I've got a 2006 Mini Cooper JCW GP and the air conditioner seems to have died. When I turn the fan on in the car and push the AC button, it lights green as it should, then starts to blink after about 10 seconds. No cold air is blown.
Anyone have an idea of where to start checking on this thing? If this were my truck I could put my hand on each component of the AC system and diagnose it. I can't even find the compressor in the Mini....
I've got the TIS, which doesn't seem to have info on this issue.
Your help is appreciated.
Old Jul 30, 2009 | 03:21 PM
icewhite's Avatar
icewhite
I just discovered the same problem on my 2006... any answers?
Old Jul 30, 2009 | 03:57 PM
R52WUF's Avatar
R52WUF
me too! What is going on???
Old Jul 31, 2009 | 12:57 PM
pogipaul's Avatar
pogipaul
happened to me too. check the 5 amp fuse under the hood. there's 2 of them, forgot which one is for the a/c. look at both, i am certain one of them is busted.
Old Aug 4, 2009 | 12:26 PM
Creech's Avatar
Creech
Nope. Checked each of the fuses in the fuse block and we're solid all the way across. Any other ideas?
Old Dec 16, 2009 | 09:21 PM
slocraiger's Avatar
slocraiger
anyone ever figure this out... my a/c in my "06MCS just died and has the flashing light as well.
Old Dec 16, 2009 | 11:54 PM
Creech's Avatar
Creech
Turns out my schrader valve which is used to load freon leaked, leaking out all the freon. The system wouldn't build pressure, thus the blinking light was merely telling me the system wasn't pressurizing. Check and see if you have pressure in the freon system. Replacing the schrader valve and recharging the system fixed the problem.
Dec 23, 2015 10:36 AM
Zettinger
Aug 25, 2015 04:04 PM
dscott90000
Aug 21, 2015 07:07 PM
truedrew
R60/R61 Stock Problems/Issues
Aug 10, 2015 10:39 AM
