HELP - Brakes are off and...
Old Jul 26, 2009 | 08:53 AM
ninjamini's Avatar
ninjamini
Help the brakes are off and the new brake sensor is not the right one. ITs not even close to the same wire. Any advice?
Old Jul 26, 2009 | 08:57 AM
Dr Obnxs's Avatar
Dr Obnxs
Need some more info...
any chance of posting some photos?
Also, to see some graphics of what's going on, check www.realoem.com
Matt
Old Jul 26, 2009 | 09:45 AM
ninjamini's Avatar
ninjamini
Nope it was the right sensor. I just broke it. Any advice of how to wire it with out using it?
Old Jul 26, 2009 | 10:43 AM
cct1's Avatar
cct1
Mine are up with zip ties, I use pads that don't have a slot for the sensor...
Old Jul 26, 2009 | 10:52 AM
ninjamini's Avatar
ninjamini
How do you shut the brake sensor light?
Old Jul 26, 2009 | 11:32 AM
ignote's Avatar
ignote
Cut the end off and tie it together with a wire nut.
If you are good enough to change your own pads, then you are one that
will watch how the pads are wearing anyway. You don't need the sensor.
Old Jul 26, 2009 | 11:41 AM
Phantom's Avatar
Phantom
+5
Old Jul 26, 2009 | 02:00 PM
Capt_bj's Avatar
Capt_bj
do note that to get the sensor lite OFF after changing (or tricking) the sensor: Turn the ignition to #2 position w/out turning the car over and let it sit for around 30 seconds. This should reset the sensor
Old Jul 26, 2009 | 05:48 PM
ninjamini's Avatar
ninjamini
That did it. I now have 4 wheels with new brakes and rotors. Thanx to my friend Russ who came down with some tools and did it. Its not hard but it is tiring. Now off to my power steering problem. I'm gonna start a new thread.
Tires, Wheels & Brakes
Sep 10, 2015 12:27 PM
Sep 10, 2015 10:52 AM
Tinklespout
16
Sep 6, 2015 11:39 AM
Sep 4, 2015 09:23 AM
PelicanParts.com
Sep 3, 2015 03:22 PM
