Pulsating noise when turning right
Old Jul 17, 2009 | 08:41 PM
jollyroger927's Avatar
jollyroger927
Lately i've been hearing a strange pulsating noise(cant describe it any better) when i turn right. its more noticible at slow speeds when the engine is quieter. I havent noticed it when i turn left at all really. But it might be getting worse. My mini is an 05 cooper s with 60,000 miles. Any ideas? I searched a little but couldnt find my problem exactly. Thanks.
Posibly the steering rack going bad? just read that. they say thats a creaking noise. i wouldnt describe mine as creaking, its rather a pulsating thump noise.
Old Jul 18, 2009 | 05:23 AM
Capt_bj's Avatar
Capt_bj
I'd be looking at the wheel bearings.
Jack up front end, take off wheel, grab the rotor at 12 and 6 and try to 'wobble it' - same at 3 and 9. If you feel play it is time to replace the bearing - which is done by replacing the entire hub as according to the book it only comes as a sealed unit.
Similar symptoms to my 79 when the right front went south.
Pretty straight forward task if you have sufficient tools to get the axle nut off.
If the bearings seem OK .... next stop CV joint.
Old Jul 18, 2009 | 06:31 AM
veggivet's Avatar
veggivet
I second the vote for wheel bearings, especially if the pulsing is speed dependent.
Old Jul 18, 2009 | 08:11 AM
jollyroger927
Whats the CV joint? And weird i changed my front rotors yesturday and didnt notice this, guess i could miss it. Im gonna go try and wobble it now, we'll see what happens.
Old Jul 18, 2009 | 04:58 PM
jollyroger927
I tried to wobble it and felt no movement at all.
Old Jul 18, 2009 | 05:17 PM
MiniGRM's Avatar
MiniGRM
Pulsing is most likely CV joint (constant velocity joint). This is consistent with your mileage....if it was wheel bearing the noise would more likely be fairly constant, though some louder when turning. There is one on either front wheel just in-board of the spindle (thing the brake caliper mounts to)
The CV joint allows the spinning of the driveshaft to reach the front wheel while permitting the wheel to be turned. The noise subsides when you go straight because the joint has little articulation (bend) while moving in a straight line, but is at an angle when turning which increases the load on the joint. Hope this helps.
Old Jul 18, 2009 | 06:09 PM
Capt_bj's Avatar
Capt_bj
was it doing this b4 you changed rotors or did it start then?
if it is CV - you jumped a good bit in cost and complexity of repair.
Take a look at the rubber boots on the drive shaft /axle....are they intact? If they rip you can get crud in the joint.
Old Jul 19, 2009 | 01:34 AM
jollyroger927
Okay i understand. It was happening before the rotors and still is. I'll check the boot tommorow.
Old Jul 27, 2009 | 08:50 PM
jollyroger927
Boot looked fine. Any other way to check that before i blow money on a replacement or whatever is needed.
Old Jul 31, 2009 | 08:07 AM
bswinnerton's Avatar
bswinnerton
How are the tires? Could you have one side worn down or something?
Old Jul 31, 2009 | 12:47 PM
jollyroger927
Oh my tires are gone, evenly bald as hell. lol Could this be what im hearing? When i say bald i mean if someone saw them the wrong way they might think there slicks.
Old Jul 31, 2009 | 03:20 PM
bswinnerton
Haha, that's definitely my guess.
Old Jul 31, 2009 | 05:57 PM
BWROOFCHEX's Avatar
BWROOFCHEX
both of our Minis has a strange groaning noise on very slow turns, and only one way. Turns out the manual trans fluid needed changing. We did that and no more noise.
BWROOFCHEX's Avatar
BWROOFCHEX
both 05 cooper s.
Old Jul 31, 2009 | 09:43 PM
Some Guy's Avatar
Some Guy
Aside from the fact that might be illegal, it could also be what is causing the problem. Are they the stock runflats, or any type of runflat for that matter?
Old Jul 31, 2009 | 11:19 PM
jollyroger927
Yep stock runflats and it defintly is illegal. Ive been driving cautiously and try to not drive in the rain at all now. Just ordered new wheels (1 inch wider) and want to get tires for those. Hope this is the problem that would be better then the other options hahah.
Old Aug 1, 2009 | 10:14 AM
jollyroger927
BTW ill change the fluid and see if thats it also, thanks.
rikaro
Aug 7, 2021 02:33 PM
maestro39
Oct 27, 2015 02:38 PM
Marco Guardado
Sep 15, 2015 01:22 AM
patrioticmini
Aug 20, 2015 10:54 AM
damncajun
Aug 17, 2015 08:25 PM
