R50/53 JCW Owners, I Need Your Help
Old Jul 11, 2009 | 02:45 PM
xlr8_mysoul's Avatar
xlr8_mysoul
I just got a new air filter for my JCW intake and when I was putting the cover back on I noticed the suction tube had disconnected from wherever it connects to. I tried to look where might it go but no luck. I added a pic show the tube i'm questioning about.
TIA
Old Jul 11, 2009 | 04:49 PM
desmo's Avatar
desmo
The vacuum tube has a "T" in it. the "T" usually is located next to the By-Pass valve. One side of the "T" goes to the By-Pass valve and the other side connects to the tube coming out of the air-box. The By-Pass valve is just to the left of the throttle bodyand between the two manifolds, its a little hard to reach unless you have a really small hand. Hopefully you didn't pull the vacuum line off the by-pass valve. (if you did the car will run really bad).
Good Luck,
Steven Tyler
W0TM8
Dec 19, 2019 07:50 AM
Sexual Chocolate
Mar 31, 2019 08:02 PM
FrostyFox
Oct 28, 2015 02:06 PM
theblackfalcon
Oct 11, 2015 09:49 AM
Longjas
Aug 24, 2015 06:06 AM
