VOLK TE37 Question
Old Jun 29, 2009 | 10:23 PM
NotMiniMe's Avatar
NotMiniMe
VOLK TE37 Question
Hi All. I have a big issue and big question that goes with the issue .
So I bought some Volk TE37 rims, used for a decent price. On the back of the rims it say "Ray's Eng, Made In Japan, and 4x100" and has an offset of 40. So i thought ok, it will fit the Mini S fine (BTW I have 07 MCS).
Problem
1) Found out that the lug bolts on the mini are 14-1.25
-Solved by getting Stud conversion from 14-1.25 --> 12-1.5
2) Huge issue that boggles the mind .... I tried to put the rims on and it doesn't fit? Came down my local tire shop and they say it is a 4x108 rims. Not sure how that would make sense, since the rims doens't look like it has been drilled (perfect circle lugs hole)
Any help on how to put the rims on would be nice. thanks all in advance.
Old Jun 29, 2009 | 10:35 PM
not-so-rednwhitecooper
4x108 is an odd, but not uncommon size. 4 lug Mustang, Fiesta, Contour, some older Audi, and french cars like to use that size.
Since Rays will make you anything you want, they very well could be 108. Are you sure you read the rim correctly? An 8 might look like a 0 if it covered in brake dust or you dont look closely.
Old Jun 29, 2009 | 10:51 PM
NotMiniMe's Avatar
NotMiniMe
I just doubled checked. they say 4x100. In any case if they are 108, is there any conversion kit out there that can convert the pattern? Or should maybe fill in the holes and redrill ?
Old Jun 29, 2009 | 10:56 PM
NotMiniMe's Avatar
NotMiniMe
D'oh ... did a double recheck. and notice that the "Ray" Sticker inside the rim say PCD 108!!! Sooo sad ....
Old Jun 29, 2009 | 11:00 PM
I would sell and buy a different set.
They still make these wheels, so its not like you are trying to get a rare set of wheels to fit your car.
Old Jun 30, 2009 | 06:20 AM
Dizzee Rasca1's Avatar
Dizzee Rasca1
what do you mean they don't fit?
are your studs long enough?
are you using hubcentric rings?
Old Jun 30, 2009 | 06:24 AM
MINIotaple's Avatar
MINIotaple
MINI fitment 4x100
These Rims 4x108
It's sort of like trying to put a circle block in an octagon hole
Old Jun 30, 2009 | 10:09 PM
NotMiniMe's Avatar
NotMiniMe
Yah. Well to anyone lookin @ Volk lol even if it say 4x100 imprint on the inside, look at what the sticker with the serial number PCD say lol.
Grizld700
Dec 30, 2015 10:47 AM
donniedarko
Oct 21, 2015 01:15 PM
twriter
Oct 2, 2015 03:14 PM
Carwash
Sep 15, 2015 02:02 AM
marc0011
Sep 10, 2015 10:04 PM
