Suspension SPC Camber Plate Issue????
Old Jun 28, 2009 | 12:38 PM
wzabrouski's Avatar
wzabrouski
I got a great deal on a set of SPC camber plates, so I installed them yesterday afternoon. I found 2 issues that I am trying to figure out.
1) cannot adjust to max negative camber of -2 due to not being able to tighten 2 of the 4 hex head screws down due to being under the strut tower. I thought about swapping out the hex heads for a standard 8 mm bolt which would allow me the room to tighten the 2 bolt.
2) the adjustment tab on the top of my Komi sports is hitting the top plate stopping it from going to max negative camber. I figured I could file this down slightly as it is barely hitting.
I am curious if anyone else has had any similar issues when installing camber plates? Thanks
Old Apr 2, 2012 | 03:40 PM
bahawton's Avatar
bahawton
Looking at these camber plates, too- Anyone else have feedback on Wzabrouski's question?
Old Jun 10, 2016 | 10:33 AM
Dr. Spade's Avatar
Dr. Spade
I have these, seems like the adjuster on the Koni is an issue when mocking up. A stock or non-adjustable shock should fit fine it seems.
I have Konis. If no one buys them soon I'm going to have to start cutting crap up.
W0TM8
Dec 19, 2019 07:50 AM
ebowling
90
Aug 4, 2019 09:15 AM
Minibeagle
Aug 13, 2015 10:00 AM
ClayTaylorNC
Aug 10, 2015 09:19 PM
OutMotoring
Aug 6, 2015 09:32 AM
