Suspension Strut / wheel clearance question
Old Jun 12, 2016 | 03:22 PM
rob76turbo's Avatar
rob76turbo
Hello everyone,
Just checking to see what you all think is good clearance between the wheel and strut.
Stock JCW Struts
Vorshlag Camber plates
17" Wheels running 225/45/17 Hankook Ventus R-S3
Seems to be about 3mm of clearance between the top edge of tire and strut.
Is that enough OR should I think of adding 3mm or 5mm spacers?
Thanks in advance
Old Jun 13, 2016 | 07:51 AM
gowest's Avatar
gowest
I think I remember seeing something on Tire Rack's site about a minimum of 5 mm clearance. I know I've seen that same number elsewhere as well, I think KW as well.
I have some 16x8, +42 wheels that with out the tire only clear on the side to the strut by 2 mm and I have never had a problem with them. I have run both a 205/50 and a 215/45 with no problem. The 215's side wall only cleared by 2 mm , so a 225 would not work for me in front with out spacers.
PhoR53
May 26, 2016 07:53 PM
midwestinsocal
Apr 13, 2016 11:40 AM
jmward2008
Mar 24, 2016 05:26 AM
Smitha6
Suspension
17
Mar 22, 2016 07:51 PM
midwestinsocal
Mar 18, 2016 10:36 PM
