R53 18x8 clearance question
Old Jun 22, 2009 | 06:10 PM
Type R 564's Avatar
Type R 564
well i just got these wheels and i want to know if i need to run spacers and if they will even work!
rim size is 18x8 45 offset, and im going to run 215/35/18 so they will have a little stretch to them
the rear:
there is a finger gap there
also a finger gap there
the front:
every small gap, maybe like 3mm
so with spacers will they work or stick to far out?
thanks
Fred-
Old Jun 22, 2009 | 07:24 PM
user 7082082's Avatar
user 7082082
You might need a 5mm spacer in the front just like I have. You also are going to need to trim a lot of your plastic trim off if you are lowered. I am running 215/45/17 with an 48offset and I could not bolt my front wheel on due to it hitting my coilovers. A 5mm up front fixed the problem and the rears are fine. I scraped my wheels on all 4 corners until I trimmed some plastic off and still do sometimes.
Old Jun 22, 2009 | 08:26 PM
Type R 564's Avatar
Type R 564
trim the plastic fender flares right?
Old Jun 22, 2009 | 08:32 PM
user 7082082
Yes correct. Can be done easily with an dremel. It is much easier if they are taken off as well.
Anyway, what wheels are those ?
BTW, I hope you aren't just using the OEM jack, that piece of crap tilted forward on me once before.
Old Jun 22, 2009 | 08:33 PM
Type R 564's Avatar
Type R 564
they are the rota MC from fastmini.net, ill post pics as soon as i get them on
and i know i gota get a real jack!!!
Old Jun 22, 2009 | 08:36 PM
user 7082082
One more thing, if your flares were left on the car and painted as one, then do not remove them. You would just need to jack up the car high enough to have space and just get under there and dremel everything off slowly and steady.
Old Jun 22, 2009 | 08:56 PM
Type R 564's Avatar
Type R 564
thanks for the heads up but ive taken them off before!
Old Jun 22, 2009 | 09:07 PM
Type R 564's Avatar
Type R 564
one last thing...how much should i cut off?
Old Jun 23, 2009 | 04:30 PM
user 7082082
Cut the entire inside edge. If you want you can leave a bit left. If your wheels will continue to scrape, than they will just scrape the remaining part off due to it not having to much support anymore.
Old Jun 23, 2009 | 09:41 PM
Type R 564's Avatar
Type R 564
i got them on today, the front seems fine(front is higher then rear) but the rear im probably gonna have to cut...ill post pics tomarrow!!!
Old Jun 24, 2009 | 12:42 AM
user 7082082
Sounds good. It might look fine, however, once taking hard corners it will start to scrape. You can just drive like that and start trimming once it starts rubbing.
Old Jun 24, 2009 | 06:23 AM
Alex@tirerack's Avatar
Alex@tirerack
Agreed, the rubs will look like a lighter grey grease mark, letting you know exacly where to trim.
Alex
Old Jun 24, 2009 | 09:23 AM
Hippie's Avatar
Hippie
Shoudl just clear no problem
https://www.northamericanmotoring.co...en-fk452s.html
and I am on HK lowering springs - no rubbing
twistedimages
Sep 19, 2024 04:13 AM
andrewjg1994
Jan 29, 2021 07:45 PM
madmax88
Oct 26, 2015 01:45 PM
missinmyjeep
Aug 22, 2015 07:13 PM
Emnotek
Aug 13, 2015 05:47 PM
