Interior/Exterior Checkered roof
Old Jun 22, 2009 | 07:53 AM
blainelv's Avatar
blainelv
Checkered roof
I have been wanting to check my roof for a long time so finally did it this weekend. What do you all think?
Old Jun 22, 2009 | 08:00 AM
slocraiger's Avatar
slocraiger
i like it, car is nice.
Old Jun 22, 2009 | 08:03 AM
CR&PW&JB's Avatar
CR&PW&JB
I'd like it more if you did the sunroof as well, but some checkers are better than no checkers.
Old Jun 22, 2009 | 08:27 AM
blainelv's Avatar
blainelv
Well didn't think it would look good just against the dark glass.
Old Jun 22, 2009 | 08:32 AM
mordecai's Avatar
mordecai
Interesting idea, only doing the sides without the roof; don't think I've seen one like that before. It is unique!
Old Jun 22, 2009 | 08:49 AM
CR&PW&JB's Avatar
CR&PW&JB
Could have done a perforated or full vinyl decal that included the sunroof. Either way, you'd have a black/white full roof, no glass showing.
Old Jun 22, 2009 | 10:40 AM
blainelv's Avatar
blainelv
Black/white?? It's dark silver/pure silver .
Old Jun 22, 2009 | 11:34 AM
CR&PW&JB's Avatar
CR&PW&JB
ohhhhhhh... it looked like you took a pic with an old black and white camera. That MINI needs some COLOR !!!
Point still stands. You could have used full vinyl so no glass was visible from the outside and you could have used perforated vinyl to allow light through to the interior if were so inclined.
But hey... if you're happy with the look of the roof, then I'm happy. See ?
BTW... I'm retired from the Air Force. Thanks for serving. Hope you don't hate Kunsan too much.
Old Jun 22, 2009 | 12:03 PM
jmoser's Avatar
jmoser
I did the perforated "S"/checked roof. Black and white check/ Big red S on top. I was never that happy with it. The perforated stuff just looks kinda rough. Looks good from a distance, but not up close. Of course, I installed it several years ago, and it was hard to install because it wanted to stretch. It IS nice that you can see thru the sunroof as though there wasn't any covering.
Next time I'm going to go with the vinyl. Stealthy--l think it looks good!
How hard was it to install?, and I'm not that happy with it. It looks kinda rough, looks good from a distance but not up close.
Next time I'd like to try regular vinyl or whatever the stuff is.
Old Jun 22, 2009 | 12:27 PM
CR&PW&JB's Avatar
CR&PW&JB
Yeah, I didn't go with the perforated vinyl because of the life expectancy of it versus the full vinyl. Plus, I don't really want light coming through the sunroof for various reason. And hey, it's kind of cool to see all those checkers from the inside of the car.
Old Jun 22, 2009 | 09:58 PM
blainelv's Avatar
blainelv
I have often thought that I should have gotten a "brighter" MINI but I'm not a flashy person at all. I love having the theme of just the two silvers going, even the red S was replaced with a pure silver one.
A few have mentioned it being unique to just go around the sunroof. I had never really occurred to me until other had pointed it out. Although I am pretty pleased with the end result, even though I can point out some errors no one notices.
Thank you also for your service. Kunsan isn't too bad just boring and the MINI has to stay home in the states but gets a little rest.
Old Jun 23, 2009 | 10:03 AM
jmoser's Avatar
jmoser
blainelv
I like your style, unto yourself.
I'm a chrome fan, and alot of MINI owners aren't.
Car looks good to me, not doing the sunroof doesn't bother me a bit.
I"m going with vinyl next time and I'll contemplate doing the sunroof vs not.
Motor On!
Old Jun 23, 2009 | 10:56 AM
mattsenpai's Avatar
mattsenpai
i like it.
Old Jun 23, 2009 | 05:46 PM
Malcon's Avatar
Malcon
i like it!
of course..
Old Jul 6, 2009 | 02:27 AM
dustinhxc's Avatar
dustinhxc
that looks so nice where did you get the vinyl kit?
Old Jul 7, 2009 | 12:07 AM
blainelv's Avatar
blainelv
I got the vinyl from beacon graphics, they sent color sample of the dark silver I thought looked close. One of them was almost identical to the MINIs dark silver. Then I took the roll to a local sign shop and had them cut 40 6" squares out. As for laying them out I just applied them myself.
Old Jul 7, 2009 | 05:59 AM
dustinhxc's Avatar
dustinhxc
that sounds so easy, how did you get the squares to go all the way to the edges? just trimmed them beforehand? i think i would mess one of them up!
Old Jul 7, 2009 | 06:30 AM
#20Works4me's Avatar
#20Works4me
That looks great, the Mini is a "different & unique" car and your checker is also "different & unique" good for you for doing it your way. It's subtle, doing the whole roof wouldn't be and it goes very well with the rest of your Mini, good job! Very tasteful.
Old Jul 7, 2009 | 03:20 PM
blainelv's Avatar
blainelv
All the squares were cut 6"x6" and as I reached the edges I would start laying out the square where it would match the edges. The portion that was sticking over I just carefully used a razor and removed the extra material. It wasn't very hard once it was started. The hardest part was making sure they were centered on the MINI. I used a string running from the antenna to the front centering the middle squares on the string. Since I didn't want to mess with the antenna base the square is just painted roof. Definitely need to make sure you have a squirt bottle (I used water alcohol mix) so they dont stick right away and can get out the air bubbles.
Old Jul 7, 2009 | 03:25 PM
blainelv's Avatar
blainelv
Thank you!
There is that different and unique thing again haha. I just figured it'd be obvious not to cover the sunroof plus haven't been a fan of the perforated vinyls. I have always thought my MINI was tastefully done of course I may be a bit bias.
Old Jul 7, 2009 | 06:23 PM
dustinhxc's Avatar
dustinhxc
Thanks! I think id have to get the whole set, good job !
Old Sep 25, 2010 | 12:09 AM
Alexdrod's Avatar
Alexdrod
WOW!
I was searching for EXACTLY what you did to your roof and this was my first result.
I am doing the same thing. I have a royal grey roof so hopefully it still looks as nice as yours with the pure silver on top! How is it holding up after over a year of being applied?
Old Sep 25, 2010 | 03:40 AM
Gluhwein's Avatar
Gluhwein
I'm thinking of the same thing but in blue and white - like the Bavarian flag.
USNAE2
16
Jun 17, 2022 07:17 AM
ian260
Mar 29, 2017 06:08 AM
OutMotoring
Mar 3, 2017 06:29 AM
bahman
Feb 14, 2016 10:29 AM
aldito2
Sep 30, 2015 10:44 AM
