Drivetrain Stock boost PSI
Old Jun 21, 2009 | 07:21 PM
tommy_zito's Avatar
tommy_zito
Stock boost PSI
Hey guys ive been looking around for a while, i cant seem to find what the stock boost PSI is...anyone know?
Old Jun 21, 2009 | 07:23 PM
ea6b607's Avatar
ea6b607
~10 psi for a gen 1
Old Jun 21, 2009 | 07:41 PM
malteseracer's Avatar
malteseracer
Originally Posted by ea6b607
~10 psi for a gen 1
what about gen 2 just out of curiosity
Old Jun 21, 2009 | 07:50 PM
MaxMini81's Avatar
MaxMini81
Wanderer
With a BPV, Intake, and not much else, my boost gauge consistently reads between 11 and 12
Old Jun 21, 2009 | 08:33 PM
ThumperMCS's Avatar
ThumperMCS
Depends on the year.
07's had different software and made much higher boost. 08's-09's make less. See the boost pressure survey thread on the Gen 2 Drivetrain forum...
Old Jun 22, 2009 | 08:33 AM
dustinhxc's Avatar
dustinhxc
I have an 04 with alta intake and magnaflow exhaust ( pulley and bpv are not installed yet) and it reads 9psi peak and 7psi on highway. could there be boost leak or something?
Old Jun 22, 2009 | 08:44 AM
MaxMini81's Avatar
MaxMini81
Wanderer
Yeah, almost without a doubt. I would start by installing the BPV. If yours isnt functioning right, it may cause a failure in building boost. If that doesn't do the trick (but I'd bet money it does), check the vacuum lines where you spliced in the boost gauge then the rest of the vac system because you're apparently hemorrhaging boost somewhere.
Old Jun 22, 2009 | 12:03 PM
MUShadd's Avatar
MUShadd
Only 10psi stock? That's lower than I would have guessed.
Also for reference: 15% pulley, cai, cat-back, and rmw tune = 15-16 psi for me.
Old Jun 22, 2009 | 12:23 PM
-=gRaY rAvEn=-'s Avatar
-=gRaY rAvEn=-
Moderator
JCW intake and exhaust, Detroit Tuned BPV and 17% Alta I have seen tics over 17 psi.
Old Jun 22, 2009 | 04:24 PM
kapps's Avatar
kapps
I made 10 psi stock. 15% pulley went up to 15-16 psi. All on an '02 S.
Old Jun 22, 2009 | 06:18 PM
tommy_zito's Avatar
tommy_zito
well see my buddy had some kind of ipod touch thing and it only read 9.81PSI i have ALTA CAI, 15%, i thought i should have more....i donno where my leak could be coming from...
Old Jun 22, 2009 | 06:41 PM
Fatherdeth's Avatar
Fatherdeth
I get 16 psi at WOT. That's with a 15% s/c pulley, 2% oversized crank pulley, DT BPV, and intake. Check where the line comes into the gauge. I had problems where my line cracked right there one time.
Old Jun 22, 2009 | 08:14 PM
MUShadd's Avatar
MUShadd
ipod touch?? is there some new app thats supposed to give you psi? I hope to get to 17 once my bpv is installed.
and for what its worth...EVERY forced induction car should have a real boost gauge installed. its very useful and really helps you troubleshoot.
Old Jun 22, 2009 | 08:48 PM
old81's Avatar
old81
M6
My ipod touch reading Tommy's boost using REV. for the iphone/touch via the OBD-II with a PLX wifi link. I had it data logging boost for his power run.
Basically a set of WOT runs in about a 1/3 - 1/2 of a mile.
Rev. is only reporting what is coming off the OBD. If you folks think with his mods he should be getting more, then he has a leak or other problem.
But it sure felt good on the butt-dyno.
Don
Old Jun 23, 2009 | 09:17 AM
batrugger's Avatar
batrugger
Keep in miind that pressure will decrease as you in improve flow. Cars with big valve heads and better flowing exhaust will actually read lower.
Old Jun 23, 2009 | 10:59 AM
dustinhxc's Avatar
dustinhxc
thanks! i was thinking that, when i get my bpv installed this weekend check the vac lines. thanks
Old Jun 27, 2009 | 09:30 PM
tommy_zito's Avatar
tommy_zito
i have to start looking at some of my vacuum lines....i just thought i should be somewhere around 13-14 psi...
Old Jun 29, 2009 | 04:58 PM
dustinhxc's Avatar
dustinhxc
Installed Alta 17% pulley and dtbpv and spiked at 17psi and average throughout all gears is 15psi but now i am getting some backfiring not sure what the issue is yet.
Old Jan 17, 2011 | 11:20 PM
kimban's Avatar
kimban
I'm new to the New Mini. I recently hook up a boost gauge, and I am only seeing like 7 psi max? normal driving is about 5 psi? Why are my numbers so low compare to everyone else?
Old Jan 18, 2011 | 03:37 AM
BlwnAway's Avatar
BlwnAway
Just read the earlier posts and you'll find your answer as far as what could be wrong, I actually had a small kink in my line giving me a low reading. As far as the BPV issue, 90% of the time this will be the cause if it's still the factory unit ( esp. in pre '05 cars) it usually has to do with butterfly alignment. For the cost of one of the DT/BPV's you might as well just just start there and take it out of the picture.
Old Jan 18, 2011 | 10:38 AM
kimban's Avatar
kimban
thanks for the suggestion, i will look into that.
Old Jan 18, 2011 | 10:53 AM
R53Warrior's Avatar
R53Warrior
your sig says you are in Denver. Altitude can make a major difference in boost also. You need to find another Mini so you can compare apples to apples. What boost I made at not even 100 feet of elevation will be considerably different than 5000 or whatever.
Old Oct 19, 2018 | 12:13 PM
dkdzyn's Avatar
dkdzyn
Just bumping this old thread because it is forever relevant AND I just replaced my turbo (worn housing where the wastegate actuator goes through) and most of the piping (removed noisemaker and resonator) at 125,500mi on my '08 S Clubman. Using my bluetooth ODB reader, I'm getting 35-37 inHg at full boost which equates to just over 17psi. I did NOT upgrade my turbo. Just replaced it with a like sized K03, but I DID replace my wastegate actuator vacuum line with a silicone one as well.
Old Feb 7, 2019 | 06:48 PM
IQRaceworks's Avatar
IQRaceworks
Just to chime in.......the stock S I've driven made around 10psi according to the aftermarket boost gauge. My 03' JCW made 12psi with the JCW SC pulley. It now makes around 16psi with the 17% pulley I installed.
The_Kid
Nov 3, 2016 06:30 PM
embiggenedmini
Oct 15, 2015 12:36 PM
Swaan
Sep 8, 2015 07:46 AM
Filmy
Sep 7, 2015 08:27 PM
Sep 1, 2015 04:39 PM
