Can Bus
Old Jun 19, 2009 | 07:43 PM
Flynscot0256's Avatar
Flynscot0256
Can Bus
I am lookng at a Dashhawk obdii scanner it tells me the car has to have Can bus can anyone tell me if it will work on the GP
Old Jun 19, 2009 | 09:58 PM
desmo's Avatar
desmo
The GP has the OBDII interface and doesn't use the CAN-Bus protocol like the later gen 2's. If you want to double check, the CAN protocol would require the following pins to be populated in your OBDII connector.
Pin
5 Ground
6 Data
14 Data
16 Power
This link might help a little bit http://www.auterraweb.com/obdiipinout.html
Old Jun 20, 2009 | 05:17 AM
BlimeyCabrio's Avatar
BlimeyCabrio
Correct - the OBD-II in the GP is NOT CAN compatible.
Old Jun 20, 2009 | 07:18 AM
Flynscot0256
Thanks for the answers looks like the Dash Dyno is the one to get thanks
Old Jun 20, 2009 | 07:28 AM
Dr Obnxs's Avatar
Dr Obnxs
I have a dashhawk...
it's OK but overpriced....
Matt
Old Jun 20, 2009 | 11:13 AM
Flynscot0256
Matt
I think it looks good I an thinking about the Dash dyno now as I have been told the dash hawk will not work because I do not have the Can bus on my GP
PsychoRallye
21
Feb 17, 2019 06:08 AM
FatherG
Sep 24, 2015 08:56 AM
HCClubbie47
R55 :: Clubman Talk (2008+)
Aug 24, 2015 02:16 PM
Trippy
Jul 27, 2004 08:18 AM
