Drivetrain Alta BOV installation
Old Jun 13, 2009 | 04:22 AM
iporkgoats's Avatar
iporkgoats
I am looking to install the M7 Super AGS, Alta cold boost tube and the Alta BOV today, but after reading the installation for the BOV i am not sure i'm very comfortable with the tapping and other areas of installation that can cause harm. 2 part question: Anyone install it themselves; opinions please? and after installing the other products is it going to be a pain to come back and install the BOV? I'm going to try and call tech support at Alta but i'm not sure if they are open on saturday. Any input would be greatly appreciated...this way i can start working on my mini
Old Jun 13, 2009 | 05:14 AM
XaLia's Avatar
XaLia
The best input for the alta bov is the alta boost port..
With that one you dont have to drill and tapp the manifold..I believe its the best way..
I have already installed the m7 super ags and the alta boost tubes and its better to fit all these at the same time..
Hope i helped you
Old Jun 13, 2009 | 07:00 AM
countryboyshane's Avatar
countryboyshane
I'd go with the DDM Race Intake System instead! It's much less intrusive on your engine bay and it works just as well.
Old Jun 13, 2009 | 07:55 AM
iporkgoats's Avatar
iporkgoats
Hope i helped you
I have the boost port, but i am not clear as to where that plays a role in installation. I read the instructions and i plan on reading them a few more times before i do anything. And what is the best plan of attack for installing the BOV, super AGS and cold boost tube?
Old Jun 14, 2009 | 08:07 AM
PRIMINISTAR's Avatar
PRIMINISTAR
The boost port is used to tap the neg boost to controll the dump valve so tapping wont be an issue. The aprts you have bought are like lego. they go where they fit and are pretty self explainatory. Just unbolt your Map sensor put the boost port underneith then bolt it all back up adding the mods as you go.
Old Jun 17, 2009 | 11:25 AM
countryboyshane
I have the Helix 13 BOV and it's very similar to Alta's setup. I don't have any CELs from the setup either.
YAY for un-tapped intake manifolds!
Old Jun 17, 2009 | 02:02 PM
iporkgoats's Avatar
iporkgoats
I think once i actually go to install it and see everything first hand it should make more sense
Old Jun 17, 2009 | 02:04 PM
MiniPOLACK's Avatar
MiniPOLACK
ill be installing my BOV next wednesday , thats when its excpected to arrive
Old Jun 17, 2009 | 04:45 PM
Powashiftin's Avatar
Powashiftin
Same here! Which boost gauge did you go with? I went with the VEI hi-res - saweeet
Old Jun 17, 2009 | 08:20 PM
MiniPOLACK's Avatar
MiniPOLACK
i have Auto-meter with silver face gauge.
Old Jan 31, 2010 | 08:36 PM
09MellowJCW's Avatar
09MellowJCW
Ok, I've been searching the web and this furum. I absolutely cannot find a picture of the Alta BOV installed . Does anybody have a pic or know where to find one?
I have one on the way and am curious.
Thank you.
Old Jan 31, 2010 | 08:40 PM
iporkgoats's Avatar
iporkgoats
i do, but it isn't on this computer, give me a day or two and i'll post them
Old Jan 31, 2010 | 09:12 PM
09MellowJCW
Thanks. That would be great.
Old Feb 1, 2010 | 11:58 AM
mamut's Avatar
mamut
i had it installed with the block off plate and it totally sucked...caused the yellow engine(reduced power) problem..i took off the block off plate and have it with the stock surge valve, no problems and a sweet pshhhh. sucks installing it tho, its by the firewall next to the intake manifold, so people with bigger hands have some trouble lol
Old Feb 1, 2010 | 07:48 PM
iporkgoats's Avatar
iporkgoats
I hope the pictures help. I had to resize them in order to fit, but i'll try and put a link to photo bucket with them at their normal size.
Attached Thumbnails Alta BOV installation-th_img_1564-1-.jpg   Alta BOV installation-th_img_1566-1-.jpg   Alta BOV installation-th_img_1567-1-.jpg
Old Feb 1, 2010 | 08:26 PM
iporkgoats's Avatar
iporkgoats
09MellowJCW
Hey goats,
Thanks for the pics. They're big enough for me to get the idea I have the same boost tube and BOV on the way, so I guess I'll see it in person in a couple of weeks anyway.
Old Feb 1, 2010 | 08:31 PM
09MellowJCW
Whoa! They got bigger!
Does the BOV rub on the firewall? If so, do you get vibrations and such?
Old Feb 1, 2010 | 09:12 PM
iporkgoats's Avatar
iporkgoats
I remember it was against the firewall at first but i can't remember if i was able to get it off. If i did, the clearance is only millimeters. really tight fit. But no vibrations.
Old Feb 1, 2010 | 09:17 PM
09MellowJCW
Ok. Thanks again for taking the time to put the pics up.
Old Feb 1, 2010 | 09:18 PM
ALTA_Jarid's Avatar
ALTA_Jarid
Any sound bytes or video?
adrchn
Aug 13, 2019 02:11 AM
AWOL
Mar 28, 2016 10:51 AM
squawSkiBum
Oct 2, 2015 09:21 AM
stierzy34
Sep 15, 2015 04:40 PM
