R56 One click window lift/close
Old May 27, 2009 | 12:05 AM
zoranb's Avatar
zoranb
Where from do i set the drivers window to lift/close with one click? I cant find it in the manual! Its strange but the co drivers works!
Old May 27, 2009 | 01:22 PM
OPC's Avatar
OPC
RATTUS Deserticus
One touch up is automatic, not an adjustable feature.. Sometimes, however, a reset is required.
1. Open the window by holding the switch down and continue to hold the switch down for 30 sec.
2. Close the window by holding the switch up and continue to hold the switch up for 30 sec.
That should reset the switch.
Old May 27, 2009 | 01:27 PM
genik's Avatar
genik
What could be the reason that set it to manual? I cant remember doing something, unless the mechanics (mini) did something i was unaware of when i took it in yesterday!
Old May 27, 2009 | 02:21 PM
4xAAA's Avatar
4xAAA
I understood that one click close was not an option in the States.
Down yes, up no.
Old May 27, 2009 | 02:32 PM
toolazyforalogin's Avatar
toolazyforalogin
Down yes, up no.
That was on 07's.
08-09 both have auto-up now.
spyderbret's Avatar
spyderbret
JCW Fanatic
One click close works for me on the windows, not the sunroof.....
Old May 27, 2009 | 06:24 PM
ngweibing's Avatar
ngweibing
is there a one click for conv?
Old May 27, 2009 | 07:03 PM
blackjackmark's Avatar
blackjackmark
It might sound stupid...but make sure the door is closed! That happened to me at the dealership where I was seeing if they had one touch up and I had the door open. It doesn't work when the door is open...and the MA didn't know that either!
Old May 27, 2009 | 11:18 PM
zoranb's Avatar
zoranb
Nah the door is closed hah thanx though. Anyway i made the reset by holding for 30secs and all is well now.
What i really cannot understand is why/how was is altered in the first place and why only for the drivers window? Any ideas?
Old May 28, 2009 | 04:56 AM
corcoranwtnet's Avatar
corcoranwtnet
No "one-click close" on the sunroof. And the "one-click open" only takes it to the tilt position, not fully open.
Old May 28, 2009 | 10:17 AM
Prost's Avatar
Prost
Can we retrofit one click open for the sunroof? I heard that the European version of the R55/R56 can do that
Old May 28, 2009 | 11:16 AM
MINIspud's Avatar
MINIspud
You should have auto up for driver and passenger windows. Does the window dip down a 1/2 inch when you open either door? No auto-open for the sunroof.
Hate to say it, but you might be seeing a bigger problem in the works.
Check out this LONG thread. My car had window issues as well.
https://www.northamericanmotoring.co...ow-dipper.html
Old May 28, 2009 | 03:28 PM
Ken G.'s Avatar
Ken G.
I don't think Zoran has the anti-pinch problem you're talk about, MINISpud, particularly if the reset solved the problem.
Old May 28, 2009 | 04:05 PM
zoranb's Avatar
zoranb
Its all ok now, its fixed, i made the reset and all is well now!
Old May 29, 2009 | 06:42 AM
MINIspud's Avatar
MINIspud
negative ken.
My window dipper problem had signs of the worst to come. One of them was the auto-up to stop working. In that long window dipper thread, one of the suggested fixes that works 25% of the time is to hold down the button for 15 - 30 seconds..
Hopefully its not writing on the wall and it is just a small issue, but wanted the poster to be aware of the bigger problems with the windows.
Old May 29, 2009 | 08:06 AM
mslatter's Avatar
mslatter
Co-driver??? You must be married.
Old May 29, 2009 | 10:01 AM
Dwight Walhood's Avatar
Dwight Walhood
Window Lift Zombie
I've got an '08 R56S with 14K on it when the driver's side window control went nuts. Took it to the dealer and was told there was an ECU programming error. Takes ~1hr to re-program. After 2wks, the poltergeists seem to have been vanquished. Dwight
Old May 29, 2009 | 08:49 PM
Ken G.'s Avatar
Ken G.
Originally Posted by MINIspud
negative ken.
Fair enough. No worries.
Aug 25, 2015 07:11 AM
johntotah94
Electrical
Aug 21, 2015 01:52 AM
Aug 19, 2015 12:51 PM
Aug 12, 2015 01:24 PM
