Electrical Retrofiting lighting package?
Old May 23, 2009 | 07:30 AM
jeremyy's Avatar
jeremyy
Hi,
I would be interested by retrofiting the lighting package in my '08 Cooper, I would add the light bulb under the dash(footlight) and under the door(puddle lights). Did you know if it's pre-wired?
Old May 26, 2009 | 05:16 AM
schatzy62's Avatar
schatzy62
Question, Where are you from that these were not installed from the factory.
As for the wiring i would suspect it is there as there is only a few main harnesses and i would not expect a change just for something as low on the scale as that.
Old May 26, 2009 | 05:23 AM
jeremyy's Avatar
jeremyy
Thanks for the answer Schatzy, I'm from Europe and it doesn't come from factory as in the US....
Old May 26, 2009 | 01:22 PM
schatzy62's Avatar
schatzy62
So that is why.
At the bottom of the dash panel there shoudl be retangle opening about 2" long by 3/4" wide (don't know the metric equivalents). Just above both should be a small pair of wires that would plug into the socket.
As for the door puddle lights i am not sure if the door panels are already cut out or not. Check them from the bottom and see. if there is a cutout with a filler in it pull the filler out you should be able to find the wiring it would look very similar to the ones under thedash.
Dec 23, 2015 10:36 AM
ryGuyMCS
Oct 20, 2015 02:24 PM
phrza81
Oct 10, 2015 11:37 PM
caiken
Aug 27, 2015 06:55 AM
Zettinger
Aug 25, 2015 04:04 PM
