R52 Door lock module autopsy done...results here
Old May 18, 2009 | 06:25 AM
Davidf's Avatar
Davidf
2005 MCSc: My drivers side door lock module failed (like many others). Symptoms were typical in that the door would lock, but not unlock with the remote or the lock switch. I installed a new lock module and all is ok. But, I wanted to see why these were failing, so I disassembled the module and found that one of the two electric motors (the one sitting on the work bench) had burned out. Applying 12 volts directly to the motor would cause it to run, but just barely. Sometimes the motor would not even start without a little help.
Problem is the motors are too unique to have any hope of finding replacements. So, I supose I could salvage the good motor and use it to rebuild the passenger door if it should fail in the same manner. Or, some of you with failed modules could send them to me
Attached Thumbnails Door lock module autopsy done...results here-mini-door-lock.jpg
Old May 18, 2009 | 07:15 AM
Londo's Avatar
Londo
That's the Germans for you! take something simple and over engineer it
Old May 18, 2009 | 07:34 AM
gbtr6's Avatar
gbtr6
Those motors, depending on exact size, look like slot car motors from the 70's. They are still around, and more powerful. Check out some slot car sites. It pays to still be a kid!
Perry
Old May 19, 2009 | 10:50 AM
kenatminimania's Avatar
kenatminimania
Perry
That was my first thought when I saw the pic's!
k
Old May 19, 2009 | 07:20 PM
Cadenza's Avatar
Cadenza
There was a time when "over-engineering" a component makes it more durable.
Old May 19, 2009 | 07:46 PM
Londo's Avatar
Londo
Rule of Acquisition # 82 "The flimsier the product, the higher the price"
Filmy
Sep 7, 2015 08:27 PM
Sep 4, 2015 02:34 PM
Sep 3, 2015 10:45 AM
Ntety
Sep 2, 2015 08:39 PM
spackletooms
Sep 1, 2015 10:12 PM
