Drivetrain My Latest Project
My Latest Project
Ok so I have my new intake working great. Now I want to expand the origional intake air supply opening behind the grill. I have mocked it up in tape ( I know it looks terrible, dont laugh
). But I think I want to try and make it out of Fiber glass or plastic or something. Does anyone have any ideas that mayhelp? I have zero experience, but I am a good learner. Here are some pics so you know what I mean.
No one with fiber glass experience to tell me if this is doable or to hard? I was thinking this stuff might do the job?
Instructions FAQ
Amazing hand moldable Thermoplastic - Incredible Strength.
A low melting temperature of 170° Fahrenheit making it hand moldable plastic ideal for modeling, prototyping, testing, manufacture and craft applications.
This thermoplastic material is one of a new generation of commercial polymers set to have a major impact on model making, arts and crafts and prototyping. This polymer has all the characteristics of a tough 'engineering' material yet it fuses and becomes easily moldable at just 170° Fahrenheit. It can be heated with just hot water or a hairdryer and molded by hand to create prototypes and solve manufacturing problems currently outside the capacity of other materials.
Some uses for this product include:
Model making
Armatures / frames for models
Specialized components - e.g. motor mountings
Sculpturing
Joining components together
Emergency repairs
Craft work / jewelry making casings & enclosures
Vacuum forming molds
Molds for batch producing other moldings
Prototype mechanical parts
Molding of handles
Inserts for compliant products
Molding of complete products - e.g. torches
Orthopedic appliance making material- (First aid securing splints, emergency castings etc.)
Some other uses for this Hand Moldable Thermoplastic:
Make Candle Molds with this material
Mold your own decorations with low temp plastic
Nylon strength plastic - melts in hot water! 1001 uses
Get a grip on your tools- handles that fit YOUR hand
Plastic repair material - nylon strength 1001 uses
Custom fixings & Fittings - mold plastic parts at home
Need a fancy bracelet? make your own with this material
Make Scenery with this amazing polymer material
Make your own props & scenery- high-tech polymer
Waterproof construction material - low temp polymer
Lightweight polymer for frames, struts, actuators etc.
Make Custom tools, Jigs and parts - High tech polymer
Make your own Beads! Moldable plastic - get creative!
This amazing material is very simple to use. The following instructions show how to heat using hot water.
The material can also be heated with a hairdryer. This is a safer method, but may take longer.
1. Heat some water and pour into a non metallic heat resistant container. The water must be at a temperature greater than 170°F
2. Carefully pour the required amount of material into the container.
3. After a few seconds, the granules will begin to turn transparent and will start to fuse together. When all of the granules appear clear and colorless, carefully remove from the water with a spoon.
Model making
Sculpturing
Emergency repairs
Molding of handles
That seems like a lot of work! But I can appreciate the want to tinker!
Good luck and keep us posted on the results! Also, be sure you don't seal off anything important for service etc.
Seriously, though I want to see it when it is done! Keep us all posted!
I've used cardboard & layers of masking tape, tin foil, pretty much anything with a relatively non-porous surface that's not going to melt or react to the resin/catalyst, to make fiberglass molds.
Fiberglass isn't much more difficult to work with than papermache. It is caustic , smelly, & sticky, so wear gloves, keep the garage door open, and take precautions to keep it off the rest of your car.
Charaj,
I think temps are not too high in the front/side of the hood/radiator. But it does get really wet there. You may want to make a water channel and make sure what you put there is water resistent.
I am really curious what you come up with and what gains you get. Thanks for experimenting.
I was thinking about the water, then we had all of these wildfires in Santa Barbara and I was worried about the ash. So I am going to let this one go. Instead I got the Alta PWI-2 water\Meth injection system. That can be my next new project
I will take some pics when I do the install. I think this one may be challenging. If anyone wants to make something like I was thinking about here, I would probably buy it
I will take some pics when I do the install. I think this one may be challenging. If anyone wants to make something like I was thinking about here, I would probably buy itThread
dutchhome
Sep 30, 2015 07:17 AM
R53UndaPSI
Sep 21, 2015 09:42 AM
