Suspension HKS Hyper max III coils for R56.
Old Apr 27, 2009 | 09:32 PM
danielo's Avatar
danielo
I just found these. Anyone has any experience with HKS Hypermax III coils? Just wondering if they're hard or harsh. Having read their description..... it still doesnt really tell how the car will ride. So i hope the suspension gurus can help. Thanks.
From HKS's Website:
http://www.hks-power.co.jp/for_impor...per_s_sus.html
HIPERMAX III
Series Concept: Designed and tuned for street application / daily driving.
With the Hipermax III suspension series, the driver gains increased wheel control with improved performance of all vehicle dynamics and increased driver command in all conditions. Hipermax III combines track-quality control with excellent ride and handling characteristics at real-world street speeds. HKS' all-new Hiper Linear Piston Fluid Channel System damping system creates a positive relationship between piston speed and damping force, making it possible to produce a suspension that provides track-level control and feedback with exceptional ride quality at the same time.
In addition, the Hipermax III is shock-body adjustable (most applications) to allow vehicle height adjustment without affecting spring rate and piston stroke. With the Hipermax III’s range of adjustability, precise corner balancing can be achieved. Chrome-plated cylinder shafts provide excellent durability and newly-design rubber upper mounts reduce harshness. (For most applications, optional spherical bearing mounts are also available for enhanced steering feedback.)
Key Features:
• Hiper Linear Piston – Linear progression piston adjusts oil passages for precise stroke management resulting in smoother valve movements. As piston speed increases, dampening rate linearly increases.
• Strengthened rubber upper mounts – enhanced durability
• Monotube design
• Shock-body length adjustable (most applications)
• 65mm diameter springs – Cold wound and manufactured in-house at HKS to ensure quality and consistency
• Stainless lock nut & ride height adjuster – feature anti-rust & corrosion characteristics for enhanced durability.
• 30-way adjustable dampening
• Hard chrome-plated cylinder shaft
• Non-electrolysis Nickel plated shock bodies provide durability in severe weather conditions.
• Pillowball upper mounts optional on certain applications
• Dustboots standard
• 1 year limited warranty
Here is the chart for the coils in detail. I can't work out what the damping and spring rates are as i can't read japanese. Anyone can chime in on this?
http://www.hks-power.co.jp/db/produc....aspx?N_ID=575
vetsvette
Oct 15, 2015 09:04 AM
eddyjoe
Oct 1, 2015 05:09 PM
Island maser
General Discussion
Oct 1, 2015 01:09 PM
drum6g
Sep 29, 2015 01:15 PM
kevinlhr310
Sep 27, 2015 02:31 PM
