Navigation & Audio MCS CD Player
Old Oct 10, 2003 | 12:08 PM
Darxar's Avatar
Darxar
Hay will it play MP3 files burned to a CD, or is it a standard CD player? sorry if I
did not search, too lazy.
Old Oct 10, 2003 | 02:00 PM
gobsmaked's Avatar
gobsmaked
The 2002 Cooper does not. I believe the 2003 and 2004's come with a MP3 jack. I know I have looked at getting a CD/MPS player disc changer and it is supposed to work. Otherwise the the stock CD player plays the old fashioned CD's.
Sombody else will correct me if they changed it for later versions of the MINI's.
Old Oct 10, 2003 | 02:35 PM
C4's Avatar
C4
I have burned MP3's to a CD and have been able to play them in my '02 Cooper's stock stereo system.
Old Oct 10, 2003 | 08:29 PM
Ryephile's Avatar
Ryephile
yo guys, moving this to Audio, where it will feel at home
Old Oct 13, 2003 | 10:03 AM
Darxar's Avatar
Darxar
Thanks for moving this, forgot this form was here... my bad...
my 04/03 build plays Mp3. I burned an mp3 to a cd and it worked fine... this
just keeps getting better and better...
thanks everyone for the help.
Old Oct 13, 2003 | 10:23 AM
sram24's Avatar
sram24
Quick question. Did you burn it as an actual mp3 file?
Cause I tried this, and my stereo did not recognize the cd.
Did you use folders or just put everything directly onto the disc?
Old Oct 13, 2003 | 10:29 AM
Sarcux's Avatar
Sarcux
I didn't know it could play MP3s stock... I'll have to give that a try...
Old Oct 13, 2003 | 12:44 PM
scooterboy's Avatar
scooterboy
I suspect that the people who say they've had success playing mp3 discs are really playing audio discs that were sourced from mp3 files. Big difference.
Old Oct 14, 2003 | 10:21 AM
sram24's Avatar
sram24
That would be my assumption. Can somebody clarify?
Old Oct 14, 2003 | 11:17 AM
Greatbear's Avatar
Greatbear
Moderator :: Performance Mods
The current stock CD players and changers will only play 'audio' CDs. Meaning, they are not true mp3 capable. You can create an audio CD with mp3 files as the source, but they have to be converted to CDA format in the burn process. The players seem to be able to play 'burned' discs of CD-R and CD-RW types, but these have to be audio (Redbook) formatted, not a data CD of .mp3 files.
Old Oct 22, 2003 | 08:10 AM
earlyapex's Avatar
earlyapex
Does anyone make a CD changer that will play true MP3 files and that can be controlled by the stock in-dash player? Not converted .wav files but true MP3?
Thank you.
-early
Old Oct 22, 2003 | 08:19 AM
Greatbear's Avatar
Greatbear
The Alpine CHA-S634 for one is a 6-disk mp3 changer. You need the Blitzsafe ALP DMX1 adaptor and the Alpine KCA-130B adaptor to hook it all up. The steering wheel controls will work, but you don't see the ID3 tags on the headunit display, just a disk-track number set.
From my post in this thread a while back, I think the info is still current.
_________________
'03 MCS, Dk Silver, 17" R85s, NAV, DSC (often turned off!), Packs #1 and #3, Rally lights, etc, etc. Fulton, MD. FRS 7-21
Let's Get Small!
Old Oct 23, 2003 | 08:48 AM
kenchan's Avatar
kenchan
yah, i installed the alpine 634 last week. it works great. there is a slight delay from the steering controls to the changer though.
make sure you set the 634's mode to receive MiniBus. it comes pre-set at
AiNet mode, just switch that over to "2" or MiniBus before you plug it into the
blitzsafe using the 130B harness :smile:
wildwestrider
Dec 27, 2015 08:20 PM
renchjeep
Sep 6, 2015 01:54 PM
Ntety
Sep 2, 2015 08:39 PM
