Suspension Bedding JCWs?
Old Apr 17, 2009 | 07:35 PM
MUShadd's Avatar
MUShadd
Bedding JCWs?
Is there any type of bedding process suggested for JCW brakes? I have a brand new set that I will be installing soon.
Also, those of you who have upgraded...did you notice in decrease in speed due to the extra weight?
Old Apr 19, 2009 | 12:36 PM
MUShadd's Avatar
MUShadd
has no one upgraded to jcw?...Even r56s? Dealer give you instructions for brake break in procedures?
Old Apr 19, 2009 | 12:56 PM
Krut's Avatar
Krut
Break in Period for JCW Brakes and other Items
What size JCW brakes are you getting? 12.1 or 12.4?
The break-in period for new MINI brakes including JCW brakes is 300 miles or 500 kilometers. That includes when you replace components. I generally tell people when I sell them a new MINI to drive "gently" for the first tank of gas and then after that drive normally (no heavy acceleration runs above 4,500 rpms).
For the curious:
Engine and Differentials - 1,200 miles
Tires - 200 miles
Brake system - see above
Clutch - 300 miles
Old Apr 19, 2009 | 03:24 PM
Mike S's Avatar
Mike S
I just drove mine casually the first couple hundred miles
Old Apr 19, 2009 | 03:40 PM
MUShadd's Avatar
MUShadd
thanks, because ive seen some brake components that have you go to an empty insterstate and slame the brakes repeatedly from 70mph etc.
I am not sure what size JCWs I have. I was completely unaware there were two sizes. Well, i know 2nd gen jcw are different than first gen jcw (aka 2nd gen stock).
Thats what I have though....New brakes from an 08 model. I assume those are 12.1?
Old Apr 19, 2009 | 03:47 PM
Krut's Avatar
Krut
Way to find out Brake Disc Size
If your disc brake caliper says John Cooper Works you'll need to measure across the disc for either 12.1 or 12.4 inches. If its 12.4 inches you have the Brembo 4 piston brakes versus the first version of the John Cooper Works 2 piston brakes at 12.1 inches.
Old Apr 20, 2009 | 07:45 PM
-=gRaY rAvEn=-'s Avatar
-=gRaY rAvEn=-
Moderator
Just had my JCW Sport Brake Kit installed.
No speed issues sensed, but they brake smooth like butter and are more efficient to be sure.
Excellent upgrade IMO especially since the kit came down in price from about $1,500 to $600.00. Installed at MINI - $1,100.00
Old Apr 22, 2009 | 03:14 PM
MUShadd's Avatar
MUShadd
ouch...thats an expensive install lol. i got lucky and found a new set for about $180, and will be installing them myself.
Old Apr 26, 2009 | 03:49 AM
Marwan's Avatar
Marwan
From my experience, all brake pads need bedding in procedures to be done.
Old Apr 30, 2009 | 04:35 AM
-=gRaY rAvEn=-
Moderator
Can't get these from dealer any less than $570.00 for the kit.....as that is dealer wholesale/cost, and they retail for just over that for a limited time at Morristown MINI.
Book rate for this installation is 3.7 hrs for front and rear.
And since I had 72,000 miles on the MINI, and it needed brake work anyways which would have cost me about $700.00 .........
Techincally - I ended up with the JCW Sport bake kit installed for $400.00 bucks more.....
Guess it is all on how you rationalize at things.
How do you like them so far ?
Go easy first 200 miles or so, after that they should be bedded in just fine.
Old Apr 30, 2009 | 07:16 AM
Bigshot's Avatar
Bigshot
Follow the accepted bed-in procedure from any of the pad manufacturers.
Usually some hard braking followed by a short cool off until you smell the pads burning off the excess resins.
And where did you get a set for $180.........!?
Old Apr 30, 2009 | 07:50 PM
-=gRaY rAvEn=-
Moderator
Sounds more like that he purchased used set of standard OEM R56 brakes from an 08 model.
Gil-galad
Eastern Iowa MINIs
63
Nov 17, 2016 02:54 PM
Tylerlanger1
Aug 21, 2015 03:03 PM
Aug 19, 2015 12:51 PM
Powershift
Aug 16, 2015 05:14 PM
M7Speed
Aug 12, 2015 05:16 AM
