Trunk slamming solutions???
Old Apr 16, 2009 | 02:17 PM
GreenIguana's Avatar
GreenIguana
So, I have read about the trunk slamming issues and am incuring them with my GP.... Anyone have a solution to this issue? I tried some lube, still have the issue....
Thanks GP#0364
Old Apr 17, 2009 | 08:23 AM
iflymini's Avatar
iflymini
What exactly is the issue?
Old Apr 17, 2009 | 08:28 AM
Bigshot's Avatar
Bigshot
You can try adjusting the rubber stops on the door.
Old Apr 17, 2009 | 09:00 AM
howsoonisnow1985's Avatar
howsoonisnow1985
Trunk Slamming?
Close it gently, maybe?
Old Apr 21, 2009 | 09:51 PM
GreenIguana
I try to close gently or with a gentle push but am getting the warning light that it is open. Have to almost 'slam' it to get it to shut.
you can adjust the rubber bumpers? will look at that.
Old Apr 22, 2009 | 06:56 AM
quikmni's Avatar
quikmni
You can twist the rubber bumpers to adjust but it probably will not help much. I have the same problem on my GP and I had the same problem on my 2003 MCS. Sometimes it takes multiple slams to get it to close. I played around with the rubber bumbers on my 2003 MCS with no real improvement.
Old Apr 22, 2009 | 07:02 AM
gokartride's Avatar
gokartride
The rubber bumper adjustment worked for me on both my '03 and my '07.
Old Apr 22, 2009 | 07:06 AM
Bigshot's Avatar
Bigshot
If the bumper (located on the door, not the body) adjustment doesn't work check with your dealer about a TSB to fix this issue. They changed the latch hoop to make it easier to latch for some.
Old Apr 22, 2009 | 01:53 PM
howsoonisnow1985
Oh ok I see
Old Jan 17, 2010 | 08:57 PM
GoodFinder's Avatar
GoodFinder
the GP slam
It would be great if there is a TSB that fixes the "GP slam" issue. All the GP owners I know have the same situation I find, which is that it requires a special "firm hand" (or "slam") to close the GP hatch. This is unique to the GP, versus other MCS variations. If anybody has any additional or more current news on this subject, I'd love to know (especially if I need to get it done under the 48K warranty, since I just passed 46K on my GP).
Old Jan 17, 2010 | 11:07 PM
quikmni's Avatar
quikmni
I do not believe this problem is not unique to the GP. My 03 MCS closed exactly the same way.
Old Jan 18, 2010 | 12:25 AM
howsoonisnow1985
Supposedly there is a TSB, its the latch thats the issue, dealer is replacing mine, cause I told them it rattles.
Old Jan 18, 2010 | 07:51 AM
It Works's Avatar
It Works
I had the same problem with both my JCW and my GP. Dealer fixed both of them.
OutMotoring
Mar 3, 2017 06:29 AM
rikaro
Nov 24, 2015 02:05 PM
Suspension Products
Oct 1, 2015 11:53 AM
FatherG
Sep 29, 2015 02:47 PM
